WTH? Phoenix Yellow paint hard to mix???
I just got a call from my body shop (who does VERY VERY good work and specializes in Honda and Acuras) and they told me what the hold up on my car was.
They said the paint code for PY doesnt give them a chart of what to mix...its like
a hit or miss game...they have to mix it until it looks about right?...this is my version of how he explained it cause I was not believing what I was hearing and
becoming a bit delusional. He said there are only a few other cars with colors like this that doesnt give them a chart to go by to mix the paint.
ARGH! I hope it comes out right..I know body shops have painted PY on other cars all around the U.S. so im sure they will get it right and mine will be fine...but Im just a tad worried I will notice I difference in color and nver be satisfied with it.
It probably depends on the paint brand and there mixing computer. The shop I work at uses Sikkens and my paint code was in the mixing computer. One thing that was weird was that my painter told me that my factory paint was single stage.
I got rear-ended in my PY R a while back and had the hatch as well as the bumper and the strip above the bumper painted 10 times, it still doesn't match. This was at a decent shop, they just couldn't do it. I finally got them to pay me $1000 to go somewhere else, but I just ended up spending the cash instead of going through the hassle again. I figure I'll just wait till I get rear-ended again, because my brakes kick so much *** it will happen again some day..
Thats really strange because I had my car re-painted all but the roof, rear hatch and rear bumper and everything matches perfectly.
my car didnt match either when it came out of the body shop for some front end work.... they ended up having to repaint the entire car.... which actually wasnt so bad. car looks pretty nice IMO.
DO NOT SETTLE FOR MISMATCHING PAINT
my car does look a little funny when sitting amongst other pY ITRS
its not bad.. just a little different
my car is about 3 different colors.
1. front lip scratched, okay match
2. someone ran into my rear bumper, that had to be repaintd twice, 2nd time by an acura certified body shop, still can see a very light difference, better than the front lip.
3. got hit with a run-away shopping cart, had the whole rear quarter panel and the piece runing along the headliner of the car all the way down to the front mirror repainted. looks decent, but you can still see the difference when comparing to the trunk.
all this and not to mention various dents i have had to get pulled, which makes for a very WAVY looking paint job.
all in all, i think py is a fabolous color, but its a BITCH to match.
The fiberglass piece will have to have a flex agent, and therefore, the paint will not match exactly. If you look at any stock integra, the bumper is usually a slightly different colour than the rest of the car! And btw, this is most aparent on the PY ITR.
Funny, my Rear OEM Lips matchs the Body paint but not the Bumper...
so it's like a zebra (if you look closer)..
but I don't care.. what I care is that B18C5 inside....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PiYoImuT »</TD></TR><TR><TD CLASS="quote">Funny, my Rear OEM Lips matchs the Body paint but not the Bumper...
<IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emsmile.gif" BORDER="0"></TD></TR></TABLE>
wow thats tiger stripes im a painter my self if you have stripes like that...That means the painter that painted your stuff was painting to close to the object and wasnt moving at a normal rate of speed while passing 50/50 over lap. It all depends on your fan patter and your air pressure of the gun also very critical... Depends what everyone is painting also all i use is PPG and Du-pont both work great for me and never had a problem with color matching PY
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 05 600RR »</TD></TR><TR><TD CLASS="quote">One thing that was weird was that my painter told me that my factory paint was single stage.</TD></TR></TABLE>
Thats because it is a single stage. Its not weird.
Wow isnt this interesting....my PY-R has been rear ended!!! thanks for finding this post ek9 citrus. this never pulled up on the car fax (of course).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YellowKahuna »</TD></TR><TR><TD CLASS="quote">2001
I'm starting to get pissed off with all the old threads being brought back for no reason.
</TD></TR></TABLE>I'm starting to get pissed off with all the old threads being brought back for no reason.
Originally Posted by Alex_G
Yellow is probably the hardest color to paint match on a car. You can try to blend it to make it less noticeable, but it'll probably never be perfect. Especially if you have the OEM paint.
here's a tip for my fellow HT members next time you buy a car either from dealer or private just to make sure they dont dick u around, Check all the the head lights and make sure its oem, all the windows and critcally check all the vin's make sure theyre still there if not means it been replaced or paited over you would see a rectangle sticker shape been painted over if it did get painted. Critically check the mil thickness of the paint they should have this gadget ur local autobody place. All i know is oem mill thickness of paint is 0.8 but if it goes over been repainted or there is body filler under, check for little dust thats visible on the paint it would look like a tiny pimple sticking out. Acura of seattle an RSX i was going to buy told me lie's and when i pin-pointed it out i asked for the manager and dropped the price on me dramatically, so it can help out in the long run
i wanted to know this too since mines will be getting re-painted soon. i think im gunna take it to acuras body shop but im not sure if id get the same results if i went to an independent body shop =/
Originally Posted by jime64871
seems like you really know what your doing, so did you spray your R?
Yup i sure did, here's an exampe of how i paint, put your surf boards away cause there are no waves
Paint used
base coat
-Du-pont Chroma Priemier Y-56
Mid-temp basemaker
clear coat
-Du-pont 7900
Mid-temp additive
