TSB's Technical Service Bulletins or Recalls, anyone know the list for the R?
Just curious if there are any. My warranty is coming up soon and want to get anything on the list inspected or replaced before it's too late.
I found out last night that there is a service bulletin regarding clutch master and related hose. I'll try to get a copy and put it up here.
-y
-y
You can find a list of all the recalls and technical service bulletins (titles only) for almost any car on the Alldata website.
For some reason, I can't bring up a list for the 1997 ITR. Here is the list for the other three years. (Remember, many TSB's are published just to assist the dealer and mechanics in diagnosing problems, and do not necessarily indicate anything that needs to be done to your car.)
Bulletins for 1998 Acura Integra Type R Coupe L4-1797cc 1.8L DOHC (VTEC) MFI
<u>Service Bulletins</u>
TSB Number Issue Date TSB Title
98-005 JUL 03 Drivetrain - Revised CV Joint Boot Band/Installation
00-037 JUN 03 Brakes - Brake Rotor Refinishing Guidelines
97-040 MAY 03 Keyless Entry - Description/Identification/Programming
03-010 MAR 03 Engine Controls/Emissions - DTC's & Monitors
03-006 MAR 03 Engine Controls - Idle Speed Inspection
02-020 AUG 02 Air Bag System - Occupant Position Sensor Initialization
02-012 MAY 02 Clutch Master Cylinder - Fluid Leakage
01-005 DEC 01 Power Steering Pump - Noise
00-037 AUG 01 Brake Disc - Refinishing Guidelines
00-039 DEC 00 Electrical - Wiring Terminal Replacement Instructions
00-028 OCT 00 A/T - MIL ON DTC P0740 Set
87-015 JUL 00 Audio System - Warranty Non Warranty Exchange/Repair
00-008 MAR 00 Torque Converter Oil Seal Installation Tool
00-001 FEB 00 Window Guide Channel Cover Comes Loose
99-048 NOV 99 Front Seat - Hard To Adjust
98-011 NOV 99 Computers/Controls - Aftermarket OBD II Tester/Software
99-033 AUG 99 PDI - Paint Damage From Environmental Fallout
86-014 JUN 99 Brakes - Brake Disc Refinishing Guidelines
90-007 MAY 99 Steering Wheel Off-Center Adjustment At TQI
92-009 FEB 99 Drivetrain - Creaking Noise While Turning
98-025 DEC 98 Sun Visor - Noise From The Passengers Side Visor
98-014 JUN 98 Transmission Control module - MIL ON/DTC 6 Set
98-004 APR 98 Audio Unit Anti-Theft Labels
98-005 APR 98 CV Joint Boots - New Band & Tool
98-010 MAR 98 Power Window - Clunk Sound From The Motor
97-046 FEB 98 Paint Code Crossover
90-009 DEC 97 A/T - Warranty Exchange Program
97-043 NOV 97 Alloy Wheel - Center Cap Missing
87-015 NOV 97 Audio Unit In-Warranty Exchange/Out-of Warranty Repair.
97-036 OCT 97 TQI and New Model Information
90-010 OCT 97 Audio Unit Error Codes
97-008 JUL 97 TQI & New Model Information
86-014 MAY 97 Brake Disc Refinishing.
97-013 MAY 97 New Halogen Leak Detector
92-032 APR 97 Handling Protective Film
97-010 MAR 97 New Fuel Pressure Gauge and Replacement Parts
97-009 MAR 97 A/T Oil Pressure Testing Tools Update
97-001 FEB 97 SRS - Do it Yourself (Owner) 10 Year Inspection
90-014 JAN 97 Rear Trailing Arm Bushing Noise
96-039 SEP 96 Power Steering Pressure Gauge
96-033 JUL 96 SRS Inflator Simulator Tools
96-010 MAR 96 Paint Finish - Minor Repairs
96-004 MAR 96 Air Conditioning System - Performance Test
96-003 FEB 96 Belt Tension Gauge Calibration and Repair
92-020 JAN 96 Front Seat Belt Replacement Warranty Policy.
92036 NOV 92 Vehicle Fails State Inspection Emissions Test
Bulletins for 2000 Acura Integra Type R Coupe L4-1797cc 1.8L DOHC (VTEC) MFI
00-019 APR 03 Antitheft System - Type 2 System Operation/Programming
03-001 JAN 03 Emissions - MIL ON/DTC P1457 (EVAP) Set
01-025 OCT 01 Oxygen Sensor/Wiring - MIL ON/DTC P0132 Set
Bulletins for 2001 Acura Integra Type R Coupe L4-1797cc 1.8L DOHC (VTEC) MFI
<u>Safety Recalls</u>
02-019 AUG 02 Recall - Passenger Air Bag Replacement
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ph0eNix »</TD></TR><TR><TD CLASS="quote">My warranty is almost over too. Could I have a dealer check the car with all these service bulletin posted through warranty??</TD></TR></TABLE>
Sort of, but not exactly.
TSBs are for all the things that MIGHT go wrong (as well as extra instructions for various service procedures, etc). If there is anything wrong with your car, they'll fix it. They won't fix things that aren't wrong.
Feel free to take your car in and ask them to go over it and see if anything needs fixing. Let us know how it goes.
Thanks for the lists Ken.
Its been quite a while since I last saw one of those posted here (i.e., FAQ material).
[QUOTE=nsxtasy]
Thanks alot Ken
You just answered a question or a few questions that myself and Mark Basch were curious about with regards to any accumulator/ABS unit/pump issues.
Thanks again.
Thanks alot Ken
Thanks again.
Like Ken said, if you are having some symtoms of a problem outlined by the bulletin the dealer will look into it. Don't expect to go to a dealer and tell them to check out your list of concerns if you havn't experienced any problems.
THE GAME IS THICK
Acura TL, RL & ZDX
Nov 8, 2009 10:08 PM
io_burn
Jan 3, 2003 06:23 AM
