rear brake conversion CRX
Old Mar 30, 2004 | 09:40 PM
mechengine's Avatar
Default rear brake conversion CRX
I have a 88 CRX DX, and want to swap rear brake with Si components. Has anyone ever done this? I have a rear clip available to me for parts, should I go that way, or is there an aftermarket kit available? Thanks for the help.
Old Mar 30, 2004 | 09:59 PM
JOEY F.'s Avatar
Default Re: rear brake conversion CRX (mechengine)
well, before anyone gets nasty about it...using the search button will get you a bunch of threads about this rear brake swap and what you need. Now...run while you can!
Old Mar 31, 2004 | 06:03 AM
snapcase318's Avatar
Default Re: rear brake conversion CRX (JOEY F.)
Best article I've found http://www.fourthgenhatch.com/index2.html
Old Mar 31, 2004 | 06:40 AM
kid-honda's Avatar
Once you get in there you will see its all self explanitory.
It only takes a few bolts to do the swap.
Old Mar 31, 2004 | 06:48 AM
-KangaRod-'s Avatar
Default Re: (kid-honda)
if you put integra brakes on the back do you retain the stock control arms, or use the DA ones. The DA ones are too long and push the bottom of the tyres out right?
Old Mar 31, 2004 | 09:01 AM
EL Vap133's Avatar
Default Re: (-KangaRod-)
I would go with the stock control arms.
Old Mar 31, 2004 | 05:09 PM
splinter51's Avatar
Default Re: (EL Vap133)
i did the swap and everything works except for compensator arm on front. make sure you mark were it bolts to body or else the toe in will be off.
4drEF
Jan 27, 2009 03:59 PM
mitsubishiv5
Suspension & Brakes
Jan 18, 2009 07:50 PM
MelloYelloCRX
May 28, 2007 10:36 AM
lkist013
Jan 12, 2006 05:30 PM
BAZ
28
Sep 21, 2003 10:24 AM
