ZC tranny, splines and clutch ?
For a zc tranny, how many splines does the imput shaft have, and what year civic clutch is used, im asking for a friend and i wanted to make sure.
I believe its the 90-91 and up year clutches right?
thanks
pat
thanks
pat
same rules as for the Si apply - 88 ZC transmission has 21 splines - 89-91 has 20 splines - clutch depends on flywheel - 88-89 ZC flywheel uses the smaller 200mm clutch like Si - 90-91 ZC flywheel uses the larger 212mm clutch like Si
Creepshow S60
Nov 11, 2004 10:32 AM
