tried everything... i have no vtec
Old Mar 30, 2004 | 07:15 PM
ensracer's Avatar
Default tried everything... i have no vtec
long story. short vtec engages but there is no power gain i have swapped out speed sensor, distributor, ecu, vtec solenoid, checked motor oil pressure, checked head oil pressure when vtec engages, checked timing, ran solenoid to a switch and it is all ok. when i lean into it in second you car hear a very light noise around 5000 rpm's but there is no power gain. i had an h23 vtec that blew up and that thing kicked super hard and now i put in an h22a4 block with type s pistons with the same h22a head and i got nothing. not even the slightest bit of power. vtec is working but there is just absolutely no power at all it runs like an non vtec with good compression. this thing absoultely dies at around 6800 rpm's.
wait i guess it is a long story.....sorry
Old Mar 30, 2004 | 07:22 PM
98 blacksh's Avatar
Default Re: tried everything... i have no vtec (eduardo)
did you clean the solenoid screen?
Old Mar 30, 2004 | 07:32 PM
ensracer's Avatar
yea i did i even swapped out vtec solenoid
Old Mar 30, 2004 | 07:40 PM
4bidden's Avatar
Default Re: (eduardo)
You sure the sound is VTEC and not the secondaries opening?
Old Mar 30, 2004 | 07:41 PM
satan_srv's Avatar
Default Re: (4bidden)
you have no engine codes? What ecu are you using?
also this head is off the blown h23 vtec how can you be sure you didn't damage it in some way?
Old Mar 30, 2004 | 08:13 PM
ensracer's Avatar
Default Re: (satan_srv)
im using a chipped p72 and i have also tried a chipped p28
Old Mar 30, 2004 | 08:14 PM
ensracer's Avatar
im not sure if it is not damaged, i have a code 9 ...but i also tried swapping out the distributor and that did not help either
Old Mar 30, 2004 | 08:15 PM
99spanishGT
Guest
Posts: n/a
what does it red line at???
Old Mar 30, 2004 | 08:24 PM
ensracer's Avatar
Default Re: (spanishlude)
it has the red line set at like 8500 but the car dies at around 6800 rpm's
Old Mar 30, 2004 | 10:25 PM
blackdelslo's Avatar
so for sure your getting the right oil psi? i banged up my oil pan on my old h22 and it didnt get enough psi so VTEC didnt work.
Old Mar 31, 2004 | 06:03 PM
Nick M's Avatar
Default Re: (delLudeVTEC)
try eliminating variables
get yourself a plain jane p72 or a stock p13
it sounds like u have too much going on to diagnose it easily
a friend of mine had bad cam seals, that was causing low oil pressure, and limp mode, something as easy as that can result in no vtec
id try a stock p13 first
Old Mar 31, 2004 | 06:33 PM
Matgallis's Avatar
Default Re: (Nick M)
check the oil level.... would the pressure be low if the oil was low?
Old Mar 31, 2004 | 07:27 PM
ensracer's Avatar
Default Re: (Matgallis)
yea the oil pressure is good and i also checked the oil level.....like i said i have good oil pressure in the head and in the block... i checked oil pressure when vtec engages and it shoots up but still nothing.... im going to swap this head out for a stock a4 head.... i have an a1 head on an a4 block running a a4 head gasket and im going to throw on the original stock head and ill see what happens.
Old Mar 31, 2004 | 08:05 PM
mattmw88's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eduardo &raquo;</TD></TR><TR><TD CLASS="quote">im going to swap this head out for a stock a4 head.... i have an a1 head on an a4 block running a a4 head gasket and im going to throw on the original stock head and ill see what happens.</TD></TR></TABLE>
Damn, I wish I had your garage
Old Mar 31, 2004 | 08:15 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eduardo &raquo;</TD></TR><TR><TD CLASS="quote">im using a chipped p72 and i have also tried a chipped p28</TD></TR></TABLE>
neither of those ecus engage VTEC at the right time so it makes sense your VTEC seems to bog...on a p72 that's like 4400 rpm and the fuel and timing will be all wrong...
get a p13....
Old Mar 31, 2004 | 09:58 PM
ensracer's Avatar
its just that whe it was 2.3 vtec the vtec would just hit so hard it would make the tires chirp with the same ecu and now i dont know whats up.
Old Mar 31, 2004 | 10:29 PM
GladmanPerformance's Avatar
tell when you figure out this problem...
im having the exact same one.
vtec kicks in, the car hesitates and it pulls a tiny bit harder... nothing like a normal h22.
does your vtec sound super loud when it kicks in?
Old Apr 1, 2004 | 07:04 AM
ensracer's Avatar
Default Re: (GladmanPerformance)
no not at all.
Old Apr 1, 2004 | 08:14 AM
PirateMcFred's Avatar
Might be out on a limb here but what condition is your cat in? If it is clogged then it could be causing all sorts of back pressure stalling the top end. What RPM does VTEC engage? Stock Cams? 11:1 compression huh? Has it been tuned? What octane gas? If that P72 is sensing any knocking then it will pull timing. More details please...
Old Apr 1, 2004 | 08:24 AM
94vtecmn's Avatar
Old Apr 1, 2004 | 09:14 AM
skrewdlude's Avatar
did you assemble the motor? Cause I have seen this problem before. I had all proper pressure when I tested it and tried everything to fix the prob. what it ended up being was someone forgot to put in the oil control orfice in the head. So the head/block had proper pressure, but the vtec solenoid was not getting any pressure. It would be an easy piece to over look due to the fact that it is pretty small.
-Josh
Old Apr 1, 2004 | 09:30 AM
Nick M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GladmanPerformance &raquo;</TD></TR><TR><TD CLASS="quote">tell when you figure out this problem...
does your vtec sound super loud when it kicks in?</TD></TR></TABLE>
are you using a p72?
because that sounds like the symptoms of a p72 on an h22a, a real shitty dip in power before the big lobe is used for vTaK y0
Old Apr 1, 2004 | 09:49 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">
get a p13....</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick M &raquo;</TD></TR><TR><TD CLASS="quote">try eliminating variables
id try a stock p13 first</TD></TR></TABLE>
Yep, i agree, get ahold of a p13
Old Apr 1, 2004 | 11:59 AM
i got an entire P13 front clip.
im running JDM P13 ecu...
Im gonna get a hold of a friend with a 93 Sr-V... maybe try his ECU.
Old Apr 1, 2004 | 12:36 PM
ensracer's Avatar
Default Re: (skrewdlude)
forgot to put in the oil control orefice in the head? im not sure what you are talking about
