H22 Swap Help
Old Mar 30, 2004 | 06:32 PM
CamGriffin's Avatar
Default H22 Swap Help
Ok I was wondering since you know alot about imports yall could help me. I have a 97 Honda Accord w/ Manual Trans. It had a f22 motor in it then i swapped it for an 97 h22 sh motor. I bought a 97 p5p ecu for that motor but it has an immobolizer in it and i don't know how to by-pass that. So this guy told me that they made a 96 P13 ecu that is OBDII but all the p13 ecu's i have seen are OBDI was he leing about the 96's are OBDII? Then someone told me to upgrade injectors and resistor box? I am confused I need to know what all needs to be done!!I need to know what all will get my motor running right? Please Help Me
-=Cameron=-
Old Mar 30, 2004 | 07:46 PM
ludeDVR's Avatar
96 is OBDII
Old Mar 30, 2004 | 07:48 PM
Kal's Avatar
Kal
Default Re: (ludeDVR)
only some ecus in 96 were OBDII. you can probably remove the immobilizer at the dealership.
Old Mar 30, 2004 | 07:51 PM
satan_srv's Avatar
Default Re: (Kal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kal &raquo;</TD></TR><TR><TD CLASS="quote">only some ecus in 96 were OBDII. you can probably remove the immobilizer at the dealership.</TD></TR></TABLE>
what? All 96 ecus are OBDII and have no immobilizer.
Like I said to cam in PM if you run an OBDII p13 on an H22A4 motor you need the A1 345cc injectors and a resistor box to run to the injectors.
Old Mar 31, 2004 | 08:12 AM
CamGriffin's Avatar
Default Re: (satan_srv)
Will someone please help me find a 96 P13 OBDII Ecu for sale.. I cannot find one I need it for my car to run..please
JDM_TR!CC
Apr 10, 2009 03:14 PM
crxhybrid85
Mar 7, 2005 05:04 AM
conesmasher
Sep 8, 2004 07:48 AM
volklude
Jul 6, 2004 10:47 PM
