gsr IM on ls
Old Mar 30, 2004 | 06:14 PM
hatchmonkey92's Avatar
Default gsr IM on ls
my friend with a 97 gsr installed a skunk 2 IM and has his stock IM laying around. I have a 92 hatch with a LS swap and i was wondering if first the gsr IM would fit the ls and second would i see any gains? thanks
Old Mar 30, 2004 | 06:23 PM
Kataku2K3's Avatar
Default Re: gsr IM on ls (hatchmonkey92)
The bolt pattern for the B series nonVTEC cylinder heads is completely different than that of the VTEC's (which are a little more similar but still not direct bolt ups). I'm sure it is possible with a custom conversion plate but I doubt you would see any gains at all, you would probably actually lose power. I personally hate the stock P72 IN manifold and will swap it or remove the IAB's whenever possible but that's just me.
mmuller's Avatar
Mad Scientist
no, it wont bolt in.
If you really wanted to, you could modify it to fit and run it with a rpm activated switch
beast18gsr
Apr 9, 2008 07:15 PM
granturismonut
Mar 5, 2004 05:20 PM
B18Redline
Jul 24, 2003 02:27 PM
jedi27sith
Apr 8, 2003 10:42 PM
RegRedTeg
Dec 7, 2002 11:15 PM
