is there a website anywhere that can be used to ca
Old Mar 30, 2004 | 06:09 PM
dimotorsports's Avatar
Default is there a website anywhere that can be used to ca
Is there a website anywhere that can be used to calculate displacement by boore and stroke?
Old Mar 31, 2004 | 04:19 AM
JimBlake's Avatar
Default Re: is there a website anywhere that can be used to ca (dimotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dimotorsports &raquo;</TD></TR><TR><TD CLASS="quote">Is there a website anywhere that can be used to calculate displacement by boore and stroke?
(pi/4) * (bore)*(bore) * (stroke) * (how many cylinders) = displacement
It would be a kinda small website...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dimotorsports &raquo;</TD></TR><TR><TD CLASS="quote">what is pi/4? and I assume the * means multiply?</TD></TR></TABLE>
OK.... how about this
0.7854 * (bore)*(bore) * (stroke) * (how many cylinders) = displacement
And yes, the "*" means multiply.
Since you had to ask what pi/4 was, I'll explain something else, too.
If you use bore & stroke in inches, you get displacement in cubic inches.
If you want cubic centimeters you have to use bore & stroke in centimeter.
Bore & stroke are usually listed in millimeters, so you divide by 10, like this...
81.0 mm = 8.10 cm
Modified by JimBlake at 7:35 AM 4/1/2004
Old Mar 31, 2004 | 04:36 AM
Default Re: is there a website anywhere that can be used to ca (JimBlake)
Old Mar 31, 2004 | 05:17 PM
okay that makes more sense...
sorry for being such a dumbass...
Thanks for the info.
Old Mar 31, 2004 | 06:23 PM
Sliced Beard's Avatar
or you can go to the compression calcualator here and it will tell you displacement and compression after all of your variables are entered
aero97
Dec 16, 2006 04:20 AM
igo4bmx
May 18, 2006 11:47 AM
wannabe_si
May 15, 2006 01:15 AM
