compression question
Old Mar 30, 2004 | 04:56 PM
spaceman's Avatar
Default compression question
what would a thin head gasket that makes compression a little higher do to an all motor engine?
Old Mar 30, 2004 | 05:31 PM
CompressionFed's Avatar
Default Re: compression question (spaceman)
you kind of answered your own question. putting a thinner head gasket on any engine will increase compression...
Old Mar 30, 2004 | 05:32 PM
Kal's Avatar
Kal
Default Re: compression question (CompressionFed)
it would boost up hp and torque by a bit.
Old Mar 30, 2004 | 05:58 PM
Kataku2K3's Avatar
Default Re: compression question (Kal)
At std. bore on a B series motor (81mm) you can expect ~0.25:1 for every 0.010" you remove (about 1 layer). It will bump up your compression a hair but the gains aren't going to be anything at all. I personally will only raise or lower a motors compression via pistons or swapping cylinder heads in some cases. Just my $0.02 tho
Old Mar 30, 2004 | 07:58 PM
spaceman's Avatar
Default Re: compression question (Kataku2K3)
thanks for the info,reason why i asked is cuz i got a mugen head gasket and i was wondering since its thinner if it would do anything..
Old Mar 30, 2004 | 09:36 PM
mmuller's Avatar
Mad Scientist
yeah, increase would be minimal, but every little bit counts...
your cam timing will be retarded a tad
petty$rep
Nov 11, 2006 02:20 PM
d.n.d.
Jul 17, 2005 08:39 AM
NCcwITR
Mar 19, 2004 01:16 PM
Evil_Wizard
Oct 2, 2002 12:39 AM
