Re-installed factory intake - left over parts??
Old Mar 30, 2004 | 03:04 PM
thereisnospoon's Avatar
Default Re-installed factory intake - left over parts??
I just installed the factory airbox - taking out my SRI.
I put everything back as I remembered - but I have three pieces of hardware left over that I had set aside with the stock parts.
1.) 10mm nut
2.) 10mm nut with more of a flared base
3.) a 10 mm jet black screw
any ideas?
Old Mar 30, 2004 | 04:07 PM
ZTYPE_S's Avatar
Default Re: Re-installed factory intake - left over parts?? (thereisnospoon)
make sure you didnt mix youre stock 10mm nuts with other things...If youre stock intake looks the same way you had it when you took it off, it should be alright. Make sure it doesnt rattle around. If it does then you ARE missing some nuts. it should have 3 10mm nuts, 2 on the left and 1 on the right (if I'm not mistaken)
Old Mar 30, 2004 | 04:12 PM
Default Re: Re-installed factory intake - left over parts?? (ZTYPE_S)
thanks - I definitely have the long 10mm bolt, the short 10mm bolt, and the 10mm flared nut for the third mounting point installed and the box is rock solid. Beyond that - are there any other bolts/nuts that are part of the install? There was one other 10mm shorter bolt that held in the stock snorkel in the front and I put that back in. This is going to drive me nuts
Old Mar 30, 2004 | 04:19 PM
ZTYPE_S's Avatar
ok, did you put all the little screws on top to hold the intake box in place? I really dont know what youre missing??
Old Mar 30, 2004 | 04:48 PM
yep - those phillips screws are sort of permanent anyway. Everything looks fine - so I guess I won't worry about it.
Old Mar 30, 2004 | 05:10 PM
fireant's Avatar
I always seem to forget to tighten the worm-dive collar that holds the rubber elbow thing on tightly. As long as the lid is on tight, all the holes have a screw in them, and the breather hose is connected, you got it right... wait those might go with the snorkel up there by the battery.
civic46
Jan 19, 2009 05:53 AM
misha
14
Aug 27, 2006 08:49 AM
AZNracerx1989
13
Aug 29, 2005 06:49 AM
honda06si
Nov 2, 2004 03:01 PM
weakGOODJunKieS.com
Jan 5, 2004 08:03 PM
