Resetting ECU on a 94 Civic with a battery backup?
I reset my ECU today and have a battery backup on my alarm. I wasn't sure if the backup battery would effect it or not. So here is what I did...disconnect neg. battery terminal and removed both the ECU fuse and backup fuse. I let it sit like that for 15 minutes and then put everything back and let it idle for 15 minutes without touching anything. Did this reset my ECU? Did it matter that I had a battery backup?
as far as i know NO it should not.. that backup battery only operates the alarm and is triggered to power the alarm when it loses power from the main car battery! am i correct??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfedb18c1 »</TD></TR><TR><TD CLASS="quote">as far as i know NO it should not.. that backup battery only operates the alarm and is triggered to power the alarm when it loses power from the main car battery! am i correct?? </TD></TR></TABLE>
also, just a side note, to reset Honda ECU's you only have to pull the fuse for 15 seconds
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjr162 »</TD></TR><TR><TD CLASS="quote">
also, just a side note, to reset Honda ECU's you only have to pull the fuse for 15 seconds</TD></TR></TABLE>
ive found that it is better to pull it a little longer than that.. dont know why but sometimes when i do shortly the ecu does not learn the idle after i start the car back up
hatching
Audio / Security / Video
Jun 28, 2007 10:33 PM
bigslimdog
Mar 30, 2004 03:07 PM
