Fuel cells and Lovefab Manifolds!
Old Mar 30, 2004 | 01:21 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Fuel cells and Lovefab Manifolds!
How much horsepower can you get from a lovefab sidewinder?
What do you need for a fuel cell?
Modified by CrxStreetRacer at 2:32 PM 3/30/2004
Modified by CrxStreetRacer at 4:06 PM 3/30/2004
Old Mar 30, 2004 | 02:56 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Fuel cells and Lovefab Manifolds! (CrxStreetRacer)
A normal healthy young adult around 25 years old will provide around 0.8 HP on a dynojet breathing though the sidewinder, a smoker around 40% less...
yeah, that's how much your post made sence as well.
please give more details.
Stan
Old Mar 30, 2004 | 04:29 PM
EG8R's Avatar
Default Re: Fuel cells and Lovefab Manifolds! (Stan D)
In your dreams it can be as much as you like....
Old Apr 13, 2004 | 09:53 AM
jmagner's Avatar
you don't have a turbo setup how are you planning on using the lovefab sidewinder
for a fuel cell, you need the fuel cell. good question. be more specific
Old Apr 13, 2004 | 12:36 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: Fuel cells and Lovefab Manifolds! (jmagner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmagner &raquo;</TD></TR><TR><TD CLASS="quote">you don't have a turbo setup how are you planning on using the lovefab sidewinder
for a fuel cell, you need the fuel cell. good question. be more specific</TD></TR></TABLE>
Yah i am not going turbo no more i am NA!
What do u need for a fuel cell and how do you put gas in it form the top some everytime u go to the gas station u have to get in your car?
Old Apr 13, 2004 | 01:54 PM
b16_madman's Avatar
why do you want a fuel cell? dood, read up on it
Old Apr 14, 2004 | 07:28 PM
jmagner's Avatar
Default Re: Fuel cells and Lovefab Manifolds! (B16_madman)
well yes, you would have to fill it with pumpgas like that but if your planning on using pumpgas then a fuel cell probably isn't the best investment your going to make. Where does your interest lie in fuel cells, weight reduction? To install a fuel cell, your going to need the cell, a fuel pump, and fuel lines, among other things. I can't go into to much detail because i've never used one.
Old Apr 14, 2004 | 08:40 PM
FastAllmotorLsVtec
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmagner &raquo;</TD></TR><TR><TD CLASS="quote">well yes, you would have to fill it with pumpgas like that but if your planning on using pumpgas then a fuel cell probably isn't the best investment your going to make. Where does your interest lie in fuel cells, weight reduction? To install a fuel cell, your going to need the cell, a fuel pump, and fuel lines, among other things. I can't go into to much detail because i've never used one.</TD></TR></TABLE>
I want something lighter than my stock fuel tank and i want to be running abover 92 octance
paulzy
Welding / Fabrication
Nov 1, 2007 04:34 AM
Topdawgg
Nov 24, 2006 05:15 PM
zeroz
Apr 16, 2005 08:33 PM
red2004
Apr 9, 2005 09:36 PM
