Draft:Newly replaced brake pads are squeaky (2001 Accord EX)
Old Mar 30, 2004 | 09:00 AM
bswilson's Avatar
Default Draft:Newly replaced brake pads are squeaky (2001 Accord EX)
Friends, recently I began hearing a squeak from my brakes. I determined it was the normal Honda alert indicating I needed new brake pads. I have performed the procedure on my previous Honda, a 1992 Accord EX.
I replaced the front disk brake pads on my 2001 Accord EX, and everything went just as smoothly as I expected. The only thing I did differently this time was that I applied some of that CRC Disk Brake Quiet spray on the new shims.
http://www.mz3.net/articles/im...c.jpg
The problem is, my brakes squeak like crazy (only when I'm braking). I assumed that ok, well, there must be a break-in period for these new pads. But after 3 days, it has not changed. Anybody know what I can do here?
Old Mar 30, 2004 | 10:04 AM
syclone's Avatar
Default Re: Draft:Newly replaced brake pads are squeaky (bswilson)
i don't see the shims on the pads.. and you didn't apply the crc as directed (but not sure if that makes a difference).
http://www.pbase.com/syclone/brake_refresh
Old Mar 30, 2004 | 10:18 AM
Elvis1977's Avatar
did you use honda factory pads?
Old Mar 30, 2004 | 08:30 PM
under advisement's Avatar
Default Re: Draft:Newly replaced brake pads are squeaky (Elvis1977)
I was gonna ask the same question. Honda pads are pretty quiet compared to a lot of aftermarket pads. Especially if you put on a $20 cheapo pad set. If you did, goto Honda and buy a set of pads. Cheap pads lead to chewed up rotors.
Old Mar 30, 2004 | 08:37 PM
iam7head's Avatar
Default Re: Draft:Newly replaced brake pads are squeaky (under advisement)
did you turn the rotor?
tell me more about the used pad, are they wearing out normally?
lazychina
May 18, 2011 04:17 PM
khizarleo
Oct 13, 2009 05:42 PM
jlh911
May 30, 2009 10:59 AM
halfcard
May 13, 2007 09:04 PM
Ideal
Jun 3, 2005 09:21 AM
