anyone have pics of Typhoon/AEBS intake manifold?
Old Mar 29, 2004 | 11:24 PM
turbohf's Avatar
Default anyone have pics of Typhoon/AEBS intake manifold?
i have seen mostly pics of the polished manifold....i dont really like polished things i want to see some pics of the satin finish manifold....would like to see it mounted on a motor also....
Old Mar 30, 2004 | 03:32 AM
Mr.DC2TurBo's Avatar
Default Re: anyone have pics of Typhoon/AEBS intake manifold? (turbohf)
I heard those things are only good for all motor. not sure if thats true.
Old Mar 30, 2004 | 10:59 AM
turbohf's Avatar
Default Re: anyone have pics of Typhoon/AEBS intake manifold? (Mr.DC2TurBo)
well i have been doing some searching and it seems to produce more power than a ITR manifold and is cheaper, so that means i need one im building a B17A1 and the IM looks like ***, so i want something else, it will be a turboed motor....
Old Mar 30, 2004 | 11:50 AM
mskibbz-T's Avatar
I recall hearing somewhat decent things about it, mainly stemming from its cost effectiveness. No pics though...
BTW Are you from Kent/Southcenter? Trying to figure out riceboy, WA...
Old Mar 30, 2004 | 11:55 AM
SiBirdie's Avatar
Default Re: anyone have pics of Typhoon/AEBS intake manifold? (mskibbz-T)
This type of manifold are not only good for all motor. It can be use for both. people use ITR manifold on boosted cars and they see good result. So if the AEBS intake manifold make more power then a ITR manifold. There will be good power output with turbo using this manifold.
here a pics of mine.
Old Mar 30, 2004 | 12:02 PM
raene's Avatar
My friend got one and is installing it on a stock ITR engine in his EF Civic. It looks much nicer than the B16 manifold it's replacing. Satin finish, pretty rough actually, but the flanges look perfectly flat and it seems like a nice solid piece. It also seems shorter than the B16 IM - the plenum that is. For the price, I was impressed.
Old Mar 30, 2004 | 01:50 PM
turbohf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mskibbz-T &raquo;</TD></TR><TR><TD CLASS="quote">...BTW Are you from Kent/Southcenter? Trying to figure out riceboy, WA... </TD></TR></TABLE>
accually Everett.....but im living in the lynnwood/mill creek area now...
would still like some satin pics
Old Mar 30, 2004 | 02:18 PM
93LSivic's Avatar
Where are you guys buying these and how much are they?
Old Mar 30, 2004 | 02:23 PM
Smashback's Avatar
Default Re: anyone have pics of Typhoon/AEBS intake manifold? (93LSivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">Where are you guys buying these and how much are they?</TD></TR></TABLE>
I second that question.
Old Mar 30, 2004 | 02:31 PM
93LSivic's Avatar
Default Re: anyone have pics of Typhoon/AEBS intake manifold? (HatchbackComeback)
Actually I can get these all day long for a good deal. Im just interested in what the price people are paying and where are they buying from.
Old Mar 30, 2004 | 02:44 PM
Marauder's Avatar
I personally think those manifolds are a P.O.S.
Stick with a Type-R manifold, its just a copy of one.
Old Mar 30, 2004 | 02:47 PM
turbohf's Avatar
Default Re: anyone have pics of Typhoon/AEBS intake manifold? (Marauder)
well these are cheaper and have produced better dyno numbers...
they are all over eBay.... search: "B16 intake manifold"
Old Mar 30, 2004 | 02:58 PM
quikB18B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">I personally think those manifolds are a P.O.S.
Stick with a Type-R manifold, its just a copy of one.</TD></TR></TABLE>
How do you figure it's a POS? Do you have any intellegent proof to back that statement up? I have seen two dyno results of more power from Aebs manifold on a bolt on Itr, so I give it credit for making more power than an already nicely designed oem manifold.
Some people complain that it doesn't look as good as other manifolds, but for $160 who's cares. If they made one for an Ls it would already be on my car.
Itr/Skunk make similar #'s as those are basically the same manifold. This manifold makes more power it half the price of it's Skunk2 counterpart.
I give it a
Also as a reference my friend Double121 installed this on his LS vtec Turbo Si, on 15 psi Peak power stayed the same but he gained 30hp throughout his powerband. For $160 I wouldnt be complaining
Old Mar 30, 2004 | 03:36 PM
Marauder's Avatar
Default Re: anyone have pics of Typhoon/AEBS intake manifold? (quikB18B)
I have seen one in person. The casting looks like crap, and the inside casting finish also looks like crap. All the dyno numbers I have seen only show like 1 hp over a Type-R, and you can get more than 1 hp difference just from dyno run to dyno run. That's no where near the 20 hp gain that they claimed on the manifold in the begining....and I have still yet to see back-to-back dyno runs that can even get close to advertised gains.
Its just a cheaply made chinese manifold. All the vacuum fittings are glued in, and have heard of some popping out.
In my opinion, 1 hp isn't worth the effort in changing manifolds, and I prefer the factory finish of a manifold over the AEBS manifold.
The AEBS manifold is made by Professional Products, and all they do is copy manifold designs from other companies and have it produced overseas. They claim on domestic V8 manifolds to beat the companies that they copy, but looking at port designs and the overall quality of the manifolds, I highly doubt they do. The only thing they can deliver is a cheap price, but you get a cheap part.
I'd never run one on my personal car.
Old Mar 30, 2004 | 03:44 PM
raene's Avatar
The casting doesn't look like crap, it looks like it has a rough surface... IMO of course. Hardly crap, just a rough surface. It would be a crap casting if there were beads all over the place, rough edges around the flanges or warped flanges, etc. It will bolt up, and when bolted up, it has been proven to make more power than ITR... hardly crap IMO.
Old Mar 30, 2004 | 03:54 PM
turbohf's Avatar
Default Re: anyone have pics of Typhoon/AEBS intake manifold? (raene)
this post isnt about your opinions of the manifold, i have already read shitloads of them from searching.......BUT STILL NO PICS?!?!?!
Old Mar 31, 2004 | 07:42 AM
raene's Avatar
Crikey man, what do you want me to say? No no pics, I don't have a digicam. It looks like a freakin' manifold, what do you think the pics will tell you? It will still just look like a manifold. Go to the store and look at one; pics won't likely make a world of difference.
Old Mar 31, 2004 | 01:09 PM
Smashback's Avatar
The fifth post in this thread has a pic, genius.
Old Mar 31, 2004 | 01:27 PM
TURBODC4TEG's Avatar
hey guys http://www.kteller.com
has the polished for 165 i think and the satin for 145
Old Mar 31, 2004 | 01:49 PM
MilanoFury's Avatar
You can get them from Import-palace.com for like 145. and as far as it looks, look at the skunk.
Old Mar 31, 2004 | 02:36 PM
99blusi's Avatar
Default Re: (Crazy18)
Does this require a new baro sensor, the one that goes into the intake tube? It looks as if there is a spot for it to mount to the runner on the AEBS.
Old Mar 31, 2004 | 03:07 PM
raene's Avatar
Default Re: (99blusi)
That's the intake air temp sensor, and there's a spot for it on the manifold a la stock.
Old Mar 31, 2004 | 03:08 PM
99blusi's Avatar
Default Re: (raene)
Good, just ordered a mani...the corner of my stocker busted off...DOH!!!
Old Mar 31, 2004 | 07:53 PM
-Justin-'s Avatar
well i have seen pics of the manifold by itself. does anyone have pics of the manifold bolted up to a motor with the hoses run. Im interested to see how they routed them since the vacuum connections are in different places.
Old Mar 31, 2004 | 09:14 PM
raene's Avatar
Default Re: (B16EH2)
I'll try and get some when my friend gets his installed.
