engine swap in CA
Old Mar 29, 2004 | 09:55 PM
dawalude's Avatar
Default engine swap in CA
hey guys,
does anyone know what the referee asks when you go to the ref for an engine swap? my friend has a b16 sir2 in his crx...and was just wondering what he would need to do before he goes to the ref, and what he might be asked of..thanks
Old Mar 29, 2004 | 10:21 PM
cloud806's Avatar
Default Re: engine swap in CA (dawalude)
jdm engines are not eligble for state ref
Old Mar 30, 2004 | 12:11 AM
B2FiNiTY's Avatar
Default Re: engine swap in CA (cloud806)
Not true. Use b16a3 smog equipment and you can pass.
Old Mar 30, 2004 | 03:45 AM
Crank's Avatar
Default Re: engine swap in CA (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Not true. Use b16a3 smog equipment and you can pass. </TD></TR></TABLE>
Explain.
Old Mar 30, 2004 | 06:12 AM
Monty's Avatar
Default Re: engine swap in CA (Crank)
Theres a write up by optimus..on the hybrid board, and norcalcrx.org
good luck!!
Old Mar 30, 2004 | 06:51 AM
XEF-9X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crank &raquo;</TD></TR><TR><TD CLASS="quote">Explain.</TD></TR></TABLE>
if you get all the parts from a USDM DEL SOL VTEC
i.e. stock down pipe, ecu, injectors, completley convert the
car to OBD1 you can get a CA bar sticker. its not easy but
it is possible
Old Mar 30, 2004 | 06:57 AM
Crank's Avatar
Default Re: engine swap in CA (XEF-9X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XEF-9X &raquo;</TD></TR><TR><TD CLASS="quote">
it is possible</TD></TR></TABLE>
sounds like hard work.
Old Mar 30, 2004 | 07:25 AM
temp's Avatar
the del sol injectors are not necessary per sae, just a set of OBD-1 B-series injectors (i am not 100% sure if d-series injectors would work so we will stick with what i said for now), you will need the USDM intake manifold, the JDM ECU will technically work and you can pass with it although it is set to run higher octane and it could cause some lean condition problems, the stock JDM exhaust manifold/down pipe will work also, if anyone has any other questions ask away
THC07
Oct 7, 2005 07:24 PM
elduro numba1
Dec 11, 2004 08:03 AM
green91
12
Sep 9, 2004 09:17 AM
silvernick711
Nov 17, 2003 06:31 AM
customx_
Sep 17, 2003 06:12 PM
