b16 ctr n1 pully need help on what belt to use for the single pully?
Old Mar 29, 2004 | 06:54 PM
QUESTOYZ by RHanDy's Avatar
Default b16 ctr n1 pully need help on what belt to use for the single pully?
what alternator belt can i use in order for my pulley to work. the stock b16a ist gen pulley is a little bit larger than the ctr one causing the belt to be to long to tighten. any help would be greatly appreciated......thank you
Old Mar 29, 2004 | 07:13 PM
thad
Guest
Posts: n/a
Default Re: b16 ctr n1 pully need help on what belt to use for the single pully? (autopilots)
try a gsr, you can always take it back, and the alternator tensioner gives you plenty of room to work with
sikcrx80's Avatar
well i already did mine and i had a hard time finding mine.. what u can do is measure.
it took me like 3 times to get the right one..
i dont know the size of it or i would of told u. sry
Old Mar 29, 2004 | 07:53 PM
Patch's Avatar
Default Re: (sikcrx80)
I believe a 29" belt with the 3 ribs works.
Old Mar 30, 2004 | 03:06 AM
turbodav's Avatar
Default Re: (Patch)
napa 040292 work for me
Old Mar 30, 2004 | 08:40 AM
Default Re: (turbodav)
thanx man i appreciate it........alot
Old Mar 30, 2004 | 01:07 PM
Combustion Contraption's Avatar
4 ribs 745mm will do the trick as well....
DC2WhiteBoy2103
Feb 20, 2008 10:53 AM
BoostinEJ1
12
May 9, 2006 06:52 PM
sa90eg
Mar 22, 2005 08:34 PM
B18C5-EH2
Sep 6, 2004 11:59 AM
MattD@Stoptech
Jul 30, 2003 09:36 AM
