knock sensor; 5th to 4th gen
Old Mar 29, 2004 | 04:35 PM
crxrich_kid's Avatar
Default knock sensor; 5th to 4th gen
does anyone know if the knock sensor from a 5th gen would fit on a 4th gen? they look similar but the connector is a diff. color
Old Mar 29, 2004 | 07:10 PM
93ludeSi's Avatar
Default Re: knock sensor; 5th to 4th gen (crxrich_kid)
i think all honda knocks are the same, call your local dealership and ask for the part numbers to be sure
Old Mar 29, 2004 | 08:47 PM
drift's Avatar
New User
Default Re: knock sensor; 5th to 4th gen (93ludeSi)
H series has a different knock than B series... I had one break on me, swapped one from a 1995 GSR, and found out they are completely different plugs.
it may be a difference from OBD I to OBD II as mine was a 1997 harness and plug.
just for reference, the OBD I B18C had a round plug with 27mm base. the OBD II H23A block and harness I have has a square plug and a 24mm base.
krazyDOHC
Sep 16, 2003 09:32 PM
qwklude82
Jan 14, 2003 04:05 AM
W0oT
10
Aug 18, 2002 01:18 PM
