Help Still have a problem with Code 9
Just put in a new head ,Spark plug wires,Distributer cap and still have check. And I reset the ecu and still have problems. Any suggestions guys.
im assuming you didnt swap like the 2 blue wires or anything like that, this code just appeared all of a sudden. and im assuming all the wiring is stock.
ok on dist side of the main connector. there should be 2 wires on the bottom next to each other opposite that little clip that locks the 2 connectors togeher. that should read 350 to 550 ohms. post up whether it does have thos ohms or not
