Freaken code 9 comes up "Need Help"
Can some on please tell me where is the Cylinder Position Sensor is located and what can i do cause I have another Distributer in the garage just in case it's bad. Or can i fix the problem with the one I have. Thanks for the help guys.
Engine is a D16A6
Engine is a D16A6
yes its in the dist, try switch them, then reset your ecu and see if you still get the code, unless you wanna see whats exactly wrong then i can help you test to see what is wrong, let me know
O.k. First i'll trylooking inside to see if it's dirty,loosen or if it's bad. I'll check now and i'll let you know what's up.
CivicRaping
Jan 2, 2005 09:11 PM
