Would a 1000 watta amp blow my speakers?
Old Mar 29, 2004 | 09:56 AM
AaronJ's Avatar
Default Would a 1000 watta amp blow my speakers?
Hey everyone, i can get a good deal on a crappy legacy 1000 watt 4 channel amp, i have infinity kappa coaxials in the rear-and i am upgrading to some infinity reference components in the front-each speaker can handle like 100 rms.
I know the amp sucks but i know the sound quality would change greatly and it would be alot louder with an amp powering it-even tho it is a legacy do you think it would blow them? thanks
Old Mar 29, 2004 | 03:37 PM
AaronJ's Avatar
Default Re: Would a 1000 watta amp blow my speakers? (AaronJ)
anybody-would it be alright to just turn down the gains?
also-would i lose the capability to fade the speakers? i only have one set of audio output wires going to the amp
Old Mar 29, 2004 | 03:38 PM
rough_draft's Avatar
it's nto gonna put out 1000 amps.. i bet u it will put out like 300 or something..
Old Mar 29, 2004 | 04:12 PM
AaronJ's Avatar
Default Re: (rough_draft)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rough_draft &raquo;</TD></TR><TR><TD CLASS="quote">it's nto gonna put out 1000 amps.. i bet u it will put out like 300 or something..</TD></TR></TABLE>
ok......
I just realized that since i only have on set of output wires ran from my cd player to my amp only 2 of the channels would work right? so then i would have to go and get another set of output wires to run to my amp so i could have all 4 channels correct?
Another question-I only have 2 sets of amp outputs on my cd player-how can i hook up a 4 channel amp and a mono sub amp to a cd player that only has 2 amp outputs?
Old Mar 29, 2004 | 05:31 PM
Eric R's Avatar
Default Re: (AaronJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AaronJ &raquo;</TD></TR><TR><TD CLASS="quote">
ok......
I just realized that since i only have on set of output wires ran from my cd player to my amp only 2 of the channels would work right? so then i would have to go and get another set of output wires to run to my amp so i could have all 4 channels correct?</TD></TR></TABLE>
You can divide the RCA out by using two RCA "Y" but it also changes your signal inpedance.
To fade, you can only use the gain controls from the amp. Ch 1 and 2 for the fronts and Ch. 3 and 4 for the rears, or viceversa.
Another question-I only have 2 sets of amp outputs on my cd player-how can i hook up a 4 channel amp and a mono sub amp to a cd player that only has 2 amp outputs?</TD></TR></TABLE>
You can use a crossover network or split the signal with RCA "Y"s. First option sounds better.
Old Mar 29, 2004 | 05:37 PM
AaronJ's Avatar
Default Re: (Eric's R)
Yeah i just found out that they make the Y things so i could do that-But back to the first question, do you think i will be ok with the "1000" amp powering my speakers?
Old Mar 29, 2004 | 05:41 PM
Eric R's Avatar
You'll be fine as long as you know how to adjust the gains and level controls. Just listen for distortion at the sound level you usually listen music to, then turn gains down.
Note: Equalization is important too.
Old Apr 1, 2004 | 10:53 AM
13link EG's Avatar
it shouldnt blow out any speakers as long as u dont crank it too loud with alot of bass
Old Apr 1, 2004 | 01:10 PM
..::91TEG-G2::..'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AaronJ &raquo;</TD></TR><TR><TD CLASS="quote">Yeah i just found out that they make the Y things so i could do that-But back to the first question, do you think i will be ok with the "1000" amp powering my speakers?</TD></TR></TABLE>
ok.. bro.. if its a mono amp.. then you gota worry, if its a 4 channel amp or 2 channel amp.. 1000 watts doesnt go to each speaker.. take it like this... its 250x4 speakers... to get the 1000 watts, you gota bridge the amp..
and 250 is alot for most door speakers.. unless there 6x9's or something.. so just make sure you have the crossover to high so u can filter down the lows.. or if u dont have a sub, just leave it as is, but turn the gain down and the amp vol down.. and/or make sure ur bass or anything isnt up 7+ on the settings on ur deck.. that'll help protect you..
mnaines
Audio / Security / Video
13
Jan 31, 2007 02:38 AM
Rocks
Apr 7, 2005 06:38 PM
FatJoe
Oct 5, 2003 10:12 AM
SSBP DC2
Apr 18, 2003 12:22 AM
mickey513
Oct 14, 2002 03:01 PM
