AWD GSR Conversion
Old Mar 29, 2004 | 09:13 AM
Urge's Avatar
Default AWD GSR Conversion
I've been doing some reasearch, and from an all hypothetical standpoint, how easy/difficult would it be to swap in the JDM Xi AWD drivetrain into a USDM 97 GSR? Will the tranny and engine align properly? I know nothing about the ZC engine in the Xi. Or would it be easier to take an Xi and swap in a C1 motor? (Please ignore cost and availability of parts for this, I'm just trying to think this through and see if anyone knows about doing the swap.) TIA
Old Mar 29, 2004 | 09:21 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: AWD GSR Conversion (Urge)
The AWD Integra had a SOHC D-series engine, so it would be pretty much impossible to use the drivetrain on any B-series engine. Not only would it not be compatible, I'm sure it wouldn't be able to handle the power and torque of the B-series, especially a DOHC VTEC powerplant.
Old Mar 29, 2004 | 09:24 AM
Vardoulika's Avatar
THe only way this is able to be done that I am aware of is by using CRV components if you want to stick with a B-Series motor, the only down fall to the CRV AWD setup is that the power distribution is 90% front 10% rear so your not really getting all that much power to the rear wheels
Old Mar 29, 2004 | 09:53 AM
ThePro's Avatar
Default Re: AWD GSR Conversion (Vardoulika)
I bet you could send the tranny off somewhere to get the power distribution played with.
90/10... why even make the CRV AWD in the first place? What does the 10% do? "Woo hoo! With this sizzlin 130 Ft-lbs of torque, 13 of those are going to the rear wheels! I could probably move a "RED RYDER" wagon with that!"
Old Mar 29, 2004 | 11:46 AM
mrmonk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vardoulika &raquo;</TD></TR><TR><TD CLASS="quote">THe only way this is able to be done that I am aware of is by using CRV components if you want to stick with a B-Series motor, the only down fall to the CRV AWD setup is that the power distribution is 90% front 10% rear so your not really getting all that much power to the rear wheels</TD></TR></TABLE>
im calling BS
Old Mar 29, 2004 | 06:48 PM
Vardoulika's Avatar
Default Re: AWD GSR Conversion (mrmonk)
and why would you be calling BS? do a search on it and you will find that what I stated is from those that have done it
Old Mar 29, 2004 | 06:49 PM
LSTEG96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrmonk &raquo;</TD></TR><TR><TD CLASS="quote">im calling BS </TD></TR></TABLE>
ban the newb!!!!!!!!!
KingofKingz80
12
Mar 27, 2013 07:32 AM
chrisxmichael
24
Aug 31, 2011 10:02 AM
BoboyRS
Feb 19, 2009 02:07 AM
mr devious illusions
Mar 27, 2004 09:27 PM
BB6Marsh
Oct 16, 2001 06:55 PM
