New overseas member - Need help with swap
hey guys
I´m from portugal and I have a 1991 Prelude with a B20A7 engine rollin´
I´m thinkin of swapping the stock head with one with Vtec, probably with a b16a2 or a b18C4 head which I have here.
However I need the map of the ECU because some changes need to be made, does anyone have the ECU map that can help me out? I would really appreciate it because the whole swap is depending on that
What do you think about this swap?
thanx!
thanx!
i know it was possible to put the b16 or b18 head on the b20a blocks. but i thought there was alot of head modification that needed to be done. you might want to check out http://www.preludepower.com, they might have more third gen info and maybe even ecu stuff. what ecu were you goign to run on it?
denniscoles
Apr 17, 2007 09:16 PM
