Will a 91 act clutch kit fit a 89
Old Mar 28, 2004 | 09:45 PM
DC2-JRSC'd's Avatar
Default Will a 91 act clutch kit fit a 89
Is there a difference between the 89 clutches and the 91? I remember reading something about this but when I searched I couldn’t find anything.
Thanks
Old Mar 28, 2004 | 10:05 PM
To Muckin Fuch's Avatar
Default Re: Will a 91 act clutch kit fit a 89 (dan4g63)
I thought the 89 had 20 splines and the 91 had 21 splines I cant remember though someone correct me if Im wrong....
Old Mar 28, 2004 | 10:09 PM
DC 2's Avatar
I believe that only the 88's had a different spline count, and the 89-91 were the same....
Old Mar 28, 2004 | 10:15 PM
Default Re: Will a 91 act clutch kit fit a 89 (EH3B18B)
hey your right...I couldnt remember...There you go
Old Mar 28, 2004 | 10:19 PM
DC2-JRSC'd's Avatar
Default Re: Will a 91 act clutch kit fit a 89 (To Muckin Fuch)
i wonder why act has different part numbers for 89 and 90-91
Old Mar 28, 2004 | 11:16 PM
Malgerus's Avatar
89's have a slightly smaller flywheel. 90-00 are the same.
Old Mar 29, 2004 | 07:32 AM
DC2-JRSC'd's Avatar
so will i be able to use a 91 pressure plate and disk on a 89 ?
Old Mar 29, 2004 | 08:45 AM
FlexW99's Avatar
Default Re: (dan4g63)
Im in the same boat. I bought a 90-91 flywheel and clutch to fit on an 89.
You have to change the flywheel bro. yours is 200mm, you need 212 mm
Old Mar 29, 2004 | 10:24 AM
DC2-JRSC'd's Avatar
So if I want to buy a lighten flywheel which one should I buy because ive seen a lot of them that claim to fit any d-series 88-00?
Old Mar 29, 2004 | 12:37 PM
hatchblack's Avatar
buy a flywheel that specifies 1990-00 d series and you will be able to use the clutch set for the 91. or, just get a flywheel for a 90-00 - doesn't have to be aftermarket, unless you want to put the lightweight aluminum flywheel in there.
hatchet_honda
13
Nov 6, 2010 12:15 PM
Super79Dave
Jan 24, 2007 03:48 PM
Trench_Rat
10
Nov 3, 2005 06:27 PM
5thGenKing
Oct 28, 2004 06:57 AM
maximedx
Dec 18, 2001 09:58 AM
