Misfire on cold start..thoughts?
Old Mar 28, 2004 | 09:19 PM
Mr. Anderson's Avatar
From: A gas station with 87, 89, 91, 92, 93 octane, FL
Default Misfire on cold start..thoughts?
I've searched this for a while and here is what i have tried so far.
Checked timing, now set to 0, but changing it had no effect
replaced cap and rotor
checked valve lash
tried different set of injectors and plugs.
Here's the problem: Car idles noticably bad at cold start 2 seconds after starting. The CEL comes on if and only if hold I the the gas at 2k rpms. When the car warms up and the rpms fall, the car idles fine, though it will misfire at 1500 rpms rather than 2k. When the CEL does come on (does not flash) throws codes 71, 72, 73, 74. When driving: Slight miss at 3k, high rpms are fine, though I here sharp ticking in the engine block when shifting gears (rpms around 3k). I know some people have had this misfire problem before, just curious what was done to fix it. One thing I noticed is that the timing belt has about 2cm of play on the front side, wondering if I should be concerned. Thanks
2001 GS-R Turbo
Old Mar 29, 2004 | 12:22 AM
G1 TEGGY's Avatar
Default Re: Misfire on cold start..thoughts? (Mr. Anderson)
here's a reeeeal stupid solution, check the cruise button, if it's acidentally pushed in the car feels like a misfire on acceleration and the CEL comes on and stays on til you shut the car off.... i've done it, don't think it's not possible
Old Mar 29, 2004 | 05:46 AM
Default Re: Misfire on cold start..thoughts? (G1_TEGGY)
i replaced the steering wheel with an unknown jdm honda one....no cruise control. But i'll check the wire behind for safety sake. I was driving to work this morning and the ecu threw a code 13 (baro circuit to high/low)....wtf?!?! I need a hondata w/ payment plan.
GreenAdam66
Jul 29, 2016 07:28 PM
MK2 GTI
May 2, 2010 11:17 AM
Mr. Anderson
Aug 25, 2008 07:42 PM
Mike813
Honda Civic (2001 - 2005)
Jul 10, 2006 09:23 AM
See Are Ex
Jun 16, 2006 04:58 PM
