oil in coolant / leaking oil
on my engine block there is alot of oil , so i cleaned it up with some brake parts cleaner. then i noticed coolant leaking right under the distributor and a small line of oil too. right now i just checked and i have oil in the coolant reservoir. a couple of months ago i had some exhaust valves replaced with new gaskets put on and everything. im thinking the headgasket is bad, you can sort of see some oil right next to the gasket. any ideas? how much does it cost for a headgasket to get replaced? how much for the gasket itself? its a b16 motor.
its not overheating or anything either btw. how much does it cost to have a new head gasket installed? is it only the headgasket? or can it be something far more serious? i didnt have this problem before, but when the headgasket was replaced was when 2 exhaust valves got bent. what could this be?
98civc123
23
Sep 8, 2021 08:14 PM
JdmJah
16
Feb 19, 2013 06:42 PM
swizz977
49
Nov 20, 2011 03:09 PM
