Condensation from AC dripping into passenger footwell?
This happens whenever I've had the AC on for more than a matter of minutes on a hot day. I start to get dripping coming from behind the glove compartment onto the floor of the passenger side footwell. Anyone know what it could be?
i believe thats sounds like the windshield/firewall seals they are little plastic washers that crack and breack after time due to weather and crap...pick some up from the dealer i think they run 5 bucks or so...thats waht it sounds like,,,not for sure though
drain tube is prob clogged. look on the passenger side under the car. there should be a rubber hose sticking out. ream that bish out!
On my '95 Integra, the evaporator drain has a short rubber tube INSIDE the car, right at the firewall. Stick your head down in the passenger footwell & look. The bottom of the airbox kinda comes to a point at the front, with a little hose coming off. Maybe that hose came off?? Looks like it's easy for someone to kick it when they're sitting in the car.
Same thing happened to my car, my mat would be soaked by the end of a day of using AC. It wasn't the drain tube, but there was a spider web/nest in the plastic piece that the drain tube connects to. Either way, I unclogged it and no more water!
Fixit-13
Honda Accord (2013 - 2015)
Oct 19, 2017 04:38 AM
aziaticvang
Dec 20, 2007 03:09 PM
