check engine light on b16a
Old Mar 28, 2004 | 03:55 PM
jsteezy1290's Avatar
Default check engine light on b16a
i got a b16a in a 89 crx si and when i drive it hard like or rev it up my check engine light comes on
Old Mar 28, 2004 | 04:16 PM
civickiller's Avatar
Default Re: check engine light on b16a (jsteezy1290)
what code are you getting ?
Old Mar 28, 2004 | 05:52 PM
Default Re: check engine light on b16a (civickiller)
havent checked yet because everytime i shut the engine off it the light isnt on anymore
Old Mar 28, 2004 | 06:16 PM
garlic jr's Avatar
does that only happen when u go past a certain speed ? for a certain amount of time ?
Old Mar 28, 2004 | 06:17 PM
REDBARON's Avatar
Just because the check engine light is not on doesn't mean that the ecu is still not blinking the code. Check the code on the ecu and then post it so we can help you. The only way to clear the code is to reset the ecu, so if it came on then the ecu is still blinking. I'm almost centain it's the O2 sensor code.
DamnThatsRexy
Jun 17, 2013 09:58 PM
SmogKing
Aug 3, 2006 12:48 PM
n.e.coupe
Mar 7, 2006 06:08 AM
type Gendy
Apr 21, 2003 04:48 PM
projecthybrid04
12
Mar 9, 2003 02:56 PM
