TB problem - Any MAP'd TBs that will bolt onto ZC intake manifold?
Old Mar 28, 2004 | 03:41 PM
I8ayellowcrayon's Avatar
Default TB problem - Any MAP'd TBs that will bolt onto ZC intake manifold?
I have a 1989 Civic that had a D15B7 in it, and somehow the engine harness was wired for OBD1 (or at least to some extent), and I am putting my 89 DOHC ZC in. The only problem is my B7 throttle body had a MAP sensor on it, and the ZC TB doesn't. I tried to fit the B7 TB on the ZC manifold and the holes weren't the same pattern.
So I guess my question is what do I do? Do the OBD1 ZC TBs fit on the OBD0 ZCs?? Or should I just try to convert back to OBD0? I know this was confusing, but I tried to slim it down . TIA!!
Old Mar 28, 2004 | 05:48 PM
anyone know where I can find an OBD1 ZC TB?
I just realized I use too many abv's. .
Old Mar 28, 2004 | 06:11 PM
green91's Avatar
i know that a d16z6 tb has a map on it, but dont know if it will bolt up
Old Mar 28, 2004 | 06:22 PM
I don't think it will because I think the Z6 and B7 are basically the same. Thanks for the input though
Old Mar 29, 2004 | 06:17 AM
Anyone else have any ideas?
Old Mar 30, 2004 | 12:50 PM
green91's Avatar
you could easily pick up an external map sensor and get a "T" fitting and t off the vacuum line
Old Mar 30, 2004 | 06:36 PM
Hmmm, I've never heard that before! Could you explain more, or give me a link or something please!?!
Gold DA9
Dec 20, 2006 03:41 PM
hatchinprogress
May 22, 2006 10:09 AM
doubleA
Jan 7, 2006 01:22 PM
Ekay Jay
Jun 6, 2004 07:17 PM
c for sea
Aug 26, 2003 10:20 AM
