ECU codes?? will it still throw one if.....
Old Mar 28, 2004 | 03:04 PM
SleepyHF's Avatar
Default ECU codes?? will it still throw one if.....
aight as most of you know i got a mini me set up (a6 block z6 head) but i am still using the HF ECU...my check engine light is on...will it still throw the correct code??
Old Mar 28, 2004 | 03:08 PM
b_jamin's Avatar
Default Re: ECU codes?? will it still throw one if..... (ConfusedHF)
it will throw a code...but only with the problems it can read on that ecu...you might want to get an adaptor harness to run the other ecu for it to ready the codes from that ecu obd0 and obd1 have different codes...also the vtec head has more sensors that won't be read by that ecu
Old Mar 28, 2004 | 03:10 PM
b_jamin's Avatar
Default Re: ECU codes?? will it still throw one if..... (b_jamin)
i think i said that right...hopefully someone that knows a little more about the ecu's can chime in on the subject...but i gotta get going...have a good night
Michael Riegel
Jan 12, 2017 05:17 AM
corps909k
Mar 25, 2009 09:56 AM
jfields06
Dec 27, 2008 06:42 AM
CRXb18Turbo
Oct 20, 2005 05:48 PM
mrnice1058
Oct 17, 2004 08:27 AM
