Will an Oil Cooler keep my engine from consuming so much oil?
Old Oct 23, 2001 | 02:23 PM
itr501's Avatar
Default Will an Oil Cooler keep my engine from consuming so much oil?
I hit vtec alot and you know the results. So I was wondering whether an oil coolr would help the situation out. Any thoughts?
Old Oct 23, 2001 | 02:33 PM
Big Phat R's Avatar
Default Re: Will an Oil Cooler keep my engine from consuming so much oil? (itr501)
I would say get an oil temp guage first - then determine/monitor oil temperature to see if it is overheating.
Old Oct 23, 2001 | 02:35 PM
MiraiZ's Avatar
if you suspect that your engine is eating a lot of oil then use higher viscosities....oil coolers are ok, but ITR's already have built in oil coolers...
Old Oct 23, 2001 | 02:36 PM
Big Phat R's Avatar
Default Re: Will an Oil Cooler keep my engine from consuming so much oil? (MiraiZ)
....which are not sufficient for heavy-duty use
Old Oct 23, 2001 | 02:39 PM
MiraiZ's Avatar
Default Re: Will an Oil Cooler keep my engine from consuming so much oil? (Big Phat R)
but if you get an oil cooler you can have a substantial drop in pressure...work on the viscousity part first...its a cheap fix if it works...if it doesn't then consider an oil cooler
Old Oct 23, 2001 | 02:41 PM
Big Phat R's Avatar
How does it create a "substantial drop in oil pressure"?
FitsMe
Honda Fit
Apr 16, 2012 05:05 AM
