drum to disk on a crx HF????????????????????????
Old Oct 23, 2001 | 02:20 PM
allmotorEG-SI's Avatar
Default drum to disk on a crx HF????????????????????????
I really dislike my drumbrakes with a passion. I like disk for so many resons and I wnated to know whats the easyiest way to convert from drum to disk. Can I just take them off another crx , civic or what. please any help would be greatly appriciated.
Old Oct 23, 2001 | 02:23 PM
dustin's Avatar
Default Re: drum to disk on a crx HF???????????????????????? (CAMAROCRUSHER)
Get the rear brakes off a 90-91 CRX Si.
Old Oct 23, 2001 | 02:38 PM
Default Re: drum to disk on a crx HF???????????????????????? (dustin)
thats what I thought. thanks just had to make sure.
Old Oct 23, 2001 | 02:57 PM
crux131's Avatar
I've also heard you need the master cylinder from the CRX si also, might want to at least check, while hunting parts.
Oh yeah, get the factory swaybar also,...unless you already have an aftermarket add on.
MysteryWagon's Avatar
damn, there has to be another rear caliper that will fit.
Is there?
Old Oct 23, 2001 | 03:43 PM
Dank26's Avatar
Why dont you swap the front and rear over to 90-93 intergra brakes? Idid
Old Oct 23, 2001 | 03:50 PM
JohnnyM's Avatar
Default Re: drum to disk on a crx HF???????????????????????? (Dank26)
I did the swap on my civic and its the same exept for the e-brake cables. Try my link http://www.geocities.com/CapitolHill.../Disc2Drum.htm
[Modified by JohnnyM, 12:50 AM 10/24/2001]
Old Oct 23, 2001 | 05:58 PM
4wsB21a's Avatar
New User
in order to do the rear disk brake setup on a crx with drum brakes you will need the whole trailing arm from either a 90-91 crx si or any del sol. the integra's might fit, like the other guy said. but in order to do the caliper brackets and calipers for the rear, the hf needs the different spindles, hub, and mounting hardware that comes on the si or del sols. once you get those trailing arms, then you can use any choice for the calipers and pads - the teg's, si's, and del sol's are all the same calipers and pads in the rear.
Old Oct 23, 2001 | 10:29 PM
BuddhaSiR's Avatar
You can use parts from any civic up to 2000. know for a fact. Gots 99 Si rear brakes on my 88 Hb.
Old Oct 24, 2001 | 05:06 PM
4wsB21a's Avatar
New User
Default Re: drum to disk on a crx HF???????????????????????? (BuddhaSiR)
all the way up to 2000? cool. i didn't know they could swap that far up. thanks.
jacksonww
Feb 7, 2011 11:09 AM
crxhftosi
Jan 30, 2005 10:13 PM
mxler8
21
Oct 17, 2004 07:46 AM
BOSS-REX
15
Oct 2, 2004 03:56 PM
3sixtycrew
Dec 4, 2003 06:39 PM
