How to adjust sensivity of shock sensor? viper 790xv
Old Mar 28, 2004 | 08:34 AM
[626]95-GSR's Avatar
Default How to adjust sensivity of shock sensor? viper 790xv
I just recently purchased a Viper 790xv 2 way alarm.. It works great and has incredible range. I got it for a great deal too, $280 installed. Im loving it so far.
Initial testing of the unit confirmed that the shock sensor was working well. It took a pretty good hit to set it off though. Yesterday i was testing it out, and noticed that it wasnt very sensitive at all. All the triggers work, but even a hard hit doesnt set it off. How do you adjust the sensitivity of the alarm so it will do off when it should? I dont see any adjustment on the brain.
Old Mar 29, 2004 | 09:44 AM
Default Re: How to adjust sensivity of shock sensor? viper 790xv ([626]95-GSR)
need to find out
Old Mar 29, 2004 | 06:03 PM
Eric R's Avatar
If you don't see any adjustment screw in the brain, look around the steering colunm or else where for a lil black box with LEDs and adjustment screw(s). Also, a four wire plug comming out of it. If none of these exist, then the adjustment is done from the remote. Read the manual.
Old Mar 29, 2004 | 09:00 PM
Default Re: How to adjust sensivity of shock sensor? viper 790xv (Eric's R)
not in the manual.. ive been looking for it.. I also checked the brain, and i see nothing?
Old Mar 31, 2004 | 01:00 AM
MyDamCivic's Avatar
The viper 790xv has a CLEAR shock sensor, a white 4 pin harness from the brain leads to a clear box , on one side of the box (small enough to fit in the palm of your hand) is an orange dial inset in the shock sensor, use a small phillips screwdriver to adjust. Clockwise for more sensitive, counter-clockwise for less sensitive....now the hard part might be finding the shock sensor. It should be zip-tied to a bundle of wires or an air vent under the dash.
Old Mar 31, 2004 | 01:48 AM
Default Re: How to adjust sensivity of shock sensor? viper 790xv (MyDamCivic)
thanks.. now i know what to look for
froogle29
Audio / Security / Video
Mar 17, 2009 05:23 PM
alacard
Nov 12, 2008 10:12 PM
EK [30-85]
16
Dec 23, 2005 06:50 PM
Kyles ej1
Jul 3, 2004 05:59 PM
rody084
Dec 31, 2003 11:49 AM
