H22a4 head versus H22a Jdm head
Old Mar 27, 2004 | 05:31 PM
Deadly-Lude's Avatar
Default H22a4 head versus H22a Jdm head
What is the difference in these heads if there is any?
Old Mar 27, 2004 | 06:09 PM
satan_srv's Avatar
Default Re: H22a4 head versus H22a Jdm head (Deadly-Lude)
nothing of note. I'm using an A1 head on an A4 block right now.
Old Mar 27, 2004 | 09:10 PM
Gerhard_001's Avatar
The heads only have insignificant differences.
Old Mar 28, 2004 | 06:23 AM
nubs's Avatar
I don't know about the heads..... But the engines aren't much different either. Basically they are exactly the same block and whatever but the h22a has a honda port and polish, higher compression pistons, higher compression head gasket, and I think thats it. The H22 A4 is open deck and the A1 is closed deck. (I think) It could be the other way around
Old Mar 28, 2004 | 07:07 AM
satan_srv's Avatar
Default Re: H22a4 head versus H22a Jdm head (LuDeMaZtEr850)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LuDeMaZtEr850 &raquo;</TD></TR><TR><TD CLASS="quote">I don't know about the heads..... But the engines aren't much different either. Basically they are exactly the same block and whatever but the h22a has a honda port and polish, higher compression pistons, higher compression head gasket, and I think thats it. The H22 A4 is open deck and the A1 is closed deck. (I think) It could be the other way around</TD></TR></TABLE>
holy crackpipe...no one was talking about the type-s motor. JDM standard motors have slightly higher comp pistons but nothing else special.
Old Mar 28, 2004 | 09:50 AM
Default Re: H22a4 head versus H22a Jdm head (satan_srv)
Thanks guys. I was pretty sure that there was no significant difference in the heads. But i was just curious because i have a jdm head going on my a4 bottom end.
Oh and you are correct ludemazter the a4 is open deck and the a1 is closed deck.
Old Mar 28, 2004 | 09:55 AM
H22A EG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">nothing of note. I'm using an A1 head on an A4 block right now.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deadly-Lude &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guys. I was pretty sure that there was no significant difference in the heads. But i was just curious because i have a jdm head going on my a4 bottom end.
Oh and you are correct ludemazter the a4 is open deck and the a1 is closed deck.</TD></TR></TABLE>
why would you ask this guy ludemazter he has like no posts and satan just said he is running what you want to do so why dont you ask him?
Old Mar 28, 2004 | 01:14 PM
TimeRacer's Avatar
I had thought that part of the reason why the Type-S camshaft didn't work as well on the USDM heads is that our valve angle is different than the JDM market heads.
Old Mar 28, 2004 | 01:22 PM
2point6's Avatar
Default Re: H22a4 head versus H22a Jdm head (TimeRacer)
Hold on... The 98 and up head is different. Especially with the LMA's. The casting is deeper so the Correct LMA's MUST BE USED. The head is slightly smaller as well and the intake manifold studs are just slightly different. If you use the 98 head with an older manifold, you will have to enlarge the bolt holes slightly. I have seen manifolds crack when they are tightened up without enlarging the holes. Other than that, the ports are slightly better having a flatter short turn radius, which promotes slighty better flow.
Old Mar 28, 2004 | 04:26 PM
Default Re: H22a4 head versus H22a Jdm head (H22A EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A EG6 &raquo;</TD></TR><TR><TD CLASS="quote">
why would you ask this guy ludemazter he has like no posts and satan just said he is running what you want to do so why dont you ask him? </TD></TR></TABLE>
Where did you get that i directly asked ludemazter anything? I saw what satan posted. This setup is what i have, not what i want and was just curious to know if it was better in any way. So next time read the posts a little better next time.
Old Mar 28, 2004 | 08:13 PM
Wiseguy619's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">holy crackpipe...no one was talking about the type-s motor.</TD></TR></TABLE>
Haha.
coomplife05
Mar 15, 2012 08:41 PM
ken2830
Sep 12, 2009 01:16 PM
ilovemydc5
Feb 7, 2007 07:52 AM
wheelmaneg6
Jun 5, 2006 09:58 PM
ensracer
Mar 17, 2004 08:07 AM
