ECU NOT COMING ON.......
Old Mar 27, 2004 | 01:56 PM
EKRacer's Avatar
Default ECU NOT COMING ON.......
a guy i know has a crx with a b16a swap. and his computer will not come on and car will not start at all.any info will help
Old Mar 27, 2004 | 03:19 PM
jedubz's Avatar
Default Re: ECU NOT COMING ON....... (EKRacer)
Does the light on the ECU come on? ECU's should still "post" (make a light) when they have power going to them. Check wiring issues (start at the battery and work from there)
Old Mar 27, 2004 | 04:20 PM
EKRacer's Avatar
yeah ive tried that. no light what so ever,and i check the wiring to the ecu.
Old Mar 27, 2004 | 07:44 PM
civickiller's Avatar
did you check the fuse ?
Old Mar 27, 2004 | 08:25 PM
xtrafastcivic's Avatar
Default Re: ECU NOT COMING ON....... (civickiller)
does the battery have life hahah
Old Mar 27, 2004 | 08:45 PM
groundedcivic91's Avatar
Did you ground the engine wire harness. This has to be grounded, or no power
Old Mar 28, 2004 | 02:27 AM
Jonny Black's Avatar
Default Re: ECU NOT COMING ON....... (groundedcivic91)
check number 14 fuse!
EF9_RIDER37
Feb 3, 2012 05:36 PM
StOnErTuNinG
Mar 26, 2007 04:24 AM
Squad1
Nov 9, 2004 11:13 PM
simplestyles
Feb 18, 2004 07:59 PM
mrduque
Jun 12, 2002 12:01 PM
