No spark/fuel won't start
Old Mar 27, 2004 | 01:30 PM
93dx--hatch's Avatar
Default No spark/fuel won't start
well I took my car out of storage and it won't start, I have no spark or fuel
its a 92vx with a gsr bottom end and type r head
the fuel pump is good, the main relay is good and the ecu is good. I checked all the grounds, is there maybe some grounds that I can't see in the back somewhere?
I am really frustrated, please help
Old Mar 27, 2004 | 02:46 PM
InjectedPerformance's Avatar
We sell parts.
Default Re: No spark/fuel won't start (93dx--hatch)
Maybe your injectors are stuck. Throw 12 volt to them and open them up. Can you hear the fuel going into the rail?
Old Mar 27, 2004 | 06:33 PM
Default Re: No spark/fuel won't start (primo8998)
no i took off the fuel line to the rail, crank and no gas,
any other ideas?
Old Mar 27, 2004 | 07:44 PM
Super_Eg6's Avatar
something similar happen to my friends car and stupid enough as it was, it was a fuse next to the SRS fuse under the dash. we checked all the main fuses but did care to look at the fuse on top, next to the ABS and SRS fuses. I still to this date dont know what it was but since it was blown, we had no spark and fuel.
Old Mar 28, 2004 | 07:37 AM
Default Re: No spark/fuel won't start (Super_Eg6)
checked that fuse still no luck, someone help me
Old Mar 28, 2004 | 08:34 AM
civickiller's Avatar
r u sure your fuel pump is turning on, or u just assumed it was because its new or something like that ?
Old Mar 28, 2004 | 11:29 AM
Default Re: No spark/fuel won't start (civickiller)
well I replaced the fuel pump with the one in my 4 door and my 4 door was running, the fuel pump is not turning on
Old Mar 28, 2004 | 07:47 PM
ttt, I need to get this started
Old Mar 29, 2004 | 07:22 PM
Old Mar 30, 2004 | 08:02 AM
i really need help bad
Old Mar 31, 2004 | 05:40 AM
ttt
Old Mar 31, 2004 | 07:41 AM
JimBlake's Avatar
If your fuel pump isn't running for 2 seconds with key on, you're gonna have to trace it's power. Got a DMM & a circuit drawing?
Is the wiring back to the pump getting power?
If not, is that same circuit getting power right at the main relay? If is is, look for where it's broken or disconnected somewhere between there & the pump.
If not, then check to see if the main relay is getting the proper signal input. If it is, then the relay is bad.
Keep going 'upstream' in the circuit until you find something that's broken or disconnected.
KeeshaunaG7
Nov 21, 2014 06:36 PM
keslerbuilt
Jan 26, 2014 09:50 AM
gs-r94coupe
Oct 30, 2010 03:35 PM
Lobster Charles
22
Mar 19, 2009 10:24 AM
ghostcivic
Jan 16, 2007 02:46 PM
