Anyone ever put an O2 simulator on your front O2 sensor for tuning purposes?
Old Mar 27, 2004 | 10:17 AM
opto_isolator's Avatar
Default Anyone ever put an O2 simulator on your front O2 sensor for tuning purposes?
Just an idea. Newer ECU's (factory ones) tune A/F mostly off of the MAP and fron O2 sensor. Installing a piggyback ECU might not allow you to tune the car properly due to the fact that the stock ECU might attempt to compensate due to its "closed-loop" monitoring capabilities.....Wondering if anyone has ever hooked an O2 sim up to the first O2 sensor (the one which monitors A/F) for tuning purposes?
Old Mar 27, 2004 | 05:37 PM
OTT's Avatar
OTT
Pointless.
Although O2 sims are used on the exhaust system's secondary sesor after the cat so it doesnt try to adjust the ignition timing and to compensate for emmisions.
NightHawkBlack-R
Feb 16, 2009 10:28 AM
aojtin
Jul 9, 2008 01:40 PM
HONDA RR
Sep 16, 2005 03:53 PM
speed
Nov 19, 2002 04:28 PM
