Dropping fuel tank question
Old Mar 27, 2004 | 12:31 AM
Tyson's Avatar
Default Dropping fuel tank question
anyone ever drop the fuel tank and looked inside? wondering if theres typically any grime or sediment in the tank worth cleaning, and if the soft filter on the pump could be worth replacing. pics would speak a million words....
Old Mar 27, 2004 | 08:35 AM
bluecrxsi's Avatar
why are you dropping the tank to start with? yes i have dropped my tank more than once.what do you need to know?
Old Mar 27, 2004 | 08:54 AM
Malgerus's Avatar
Default Re: (bluecrxsi)
The inside of my tank was completely clean. The access plate for the fuel pump was covered in grime on the outside though. If you're putting in a new fuel pump you may as well put in a new "sock".
Old Mar 27, 2004 | 01:12 PM
Tyson's Avatar
theres no reason. the car is 15 years old, i was wondering how dirty it is in there. isnt that what i asked?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluecrxsi &raquo;</TD></TR><TR><TD CLASS="quote">why are you dropping the tank to start with? yes i have dropped my tank more than once.what do you need to know?
Old Mar 27, 2004 | 02:41 PM
Origin's Avatar
Default Re: (Tyson)
yeah, obviously that guy has some short term memory loss.
Old Mar 27, 2004 | 03:21 PM
ijjz's Avatar
Default Re: (Tyson)
I think your tank will be fine unless the pump is giving you problems, no reason why you should really drop it. Might end up having to replace more parts earlier then you thought because of you droping it and disturbing parts that have never been moved.
Old Mar 27, 2004 | 04:14 PM
hybrid88hatch's Avatar
Default Re: Dropping fuel tank question (Tyson)
When i dropped my tank to install a new fuel pump, the inside of the tank was horrible i tried cleaning it to no avail!I just thought it would be easier to go to Autozone and buy a new tank, I think it was like 130.00 but worth it to me.
Old Mar 27, 2004 | 04:37 PM
Tyson's Avatar
Default Re: Dropping fuel tank question (hybrid88hatch)
thanks, looking for replies like yours and mr S from ppl who have had to pull their tanks for one reason or another so i can get a clue as to how dirty my tank could be without doing it myself.
Old Mar 27, 2004 | 06:37 PM
civickiller's Avatar
i ripped my fuel line just the other day cause im trying to take out my tank. like that other guy said, disturbing parts u dont need too
Old Mar 27, 2004 | 07:12 PM
jisu009's Avatar
Default Re: Dropping fuel tank question (civickiller)
I just had mine out, just to look at it, clean it and brainstorm on some fuel line setup ideas. It was Grimey as heck on the top and I am glad I took it out and gave it a "once over."
Old Mar 28, 2004 | 08:17 AM
legacytunes's Avatar
Default Re: Dropping fuel tank question (jisu009)
i also have a 89 si. my tank was seriously built up with rust do to bad gas, or somthing. my fuel pump died. droping the tank was easy. you shouldnt have a problem. but i would buy a gas adative to clean it up as best as possible before you encouter pump problems as i did. keep a good look out on ebay i saw a crx si tank and fuel pump ( new ) sell for 100 bucks. good luck
Old Mar 28, 2004 | 09:25 AM
1's Avatar
Default Re: Dropping fuel tank question (legacytunes)
http://cgi.ebay.com/ebaymotors...55518
Old Mar 28, 2004 | 03:49 PM
Tyson's Avatar
Default Re: Dropping fuel tank question (1)
yeah, ive seen this seller sell these for quite some time. anyone ever bought and installed these? hows the fitment, its obviously not OEM.
Old Dec 15, 2006 | 12:09 PM
89CRX-'s Avatar
hey do you think you could send me some
pics. on how to drop the gas tank?
it's an 89 CRX. plez and thnx
Old Dec 15, 2006 | 01:02 PM
bagpipe goatee's Avatar
Tyson- I know it was two and a half years ago, and you've probably done something by now, but the fitment on all the aftermarket tanks I've seen have been fine, except they don't have the drain plug in the bottom.
Old Dec 15, 2006 | 03:45 PM
LatnKng's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">anyone ever drop the fuel tank and looked inside? wondering if theres typically any grime or sediment in the tank worth cleaning, and if the soft filter on the pump could be worth replacing. pics would speak a million words....</TD></TR></TABLE>
Yes, very ez to do. Just a few bolts. I'd say definately change the filter bag after once you got it down. And no, you wont find any grime or **** in there, unless you pissed off sum chick out there and she decided to pour sugar in there...good luck on that, cant help u there buddy.
Old Dec 15, 2006 | 05:02 PM
hotrodlincoln's Avatar
Default Re: Dropping fuel tank question (LatnKng)
wen you drop your tank also plan on buying fuel line
as far as cleaning it take it to a radiator repair shop and they can boil it in a costic chemical its cheaper than a new one and just as good
Old Dec 15, 2006 | 05:29 PM
Tyson's Avatar
Default Re: (89CRX-)
yeah, this is an old thread. just a question i was thinking about. i never did anything. im too lazy. it didnt seem urgent enough.
props to the noob for searching at least!
Uncle Ben's
Nov 16, 2007 01:23 PM
Dave4282
May 13, 2007 06:25 PM
mark2oo3
May 31, 2006 09:55 AM
b16hatche
Nov 4, 2005 08:46 PM
full Circling
Feb 23, 2005 07:47 AM
