Motor vibration-not from mounts ????
Heres the deal- after I get past 4000 RPM- If I let the car rev down (dont put in
clutch) it around 3000 RPM makes a loud vibration that is felt throughout the car
but doesnt apear to be a motor mount. The car has 91000 miles-any hints?
Mine makes a similar vibration at 2000 & 3000 rpm....I think it's the exhaust hiting something. Gonna take a closer look when the rain stops.
if it happens while your driving or taking off then check your axles if there out of grease then they cause the car to vibrate and you will never figure it out because they look fine I have this problem with mine and it happened to my teg because of cheap axles from autozone. that mite help
kenttouchthis
Aug 24, 2008 04:09 PM
