valve adj. 97 accord help.
Old Mar 26, 2004 | 05:32 PM
david90's Avatar
Default valve adj. 97 accord help.
when adjusting the valves, do the pistons have to be extactly at tdc or u can be off a little?
When #1 is at tdc, the arrow on the back of the cam sprocket is suppose to point up right? #3 is at tdc if the arrow is pointing toward the front of the car right? I'm just confuse about setting tdc to the piston. Haynes tells me to turn the crank pulley 180 for #3 tdc but how do I know exactly where that is without any mark? The manual assume that my timing belt cover is off so I can see the word "up" on the cam sprocket but I don't. All I can see is the back of the cam sprocket and a single arrow.
btw, can a valve clearance be tighten due to vibration over time or only loosen is possible?
TomCat39
Mar 14, 2015 09:15 PM
NokStrImpz
Mar 28, 2008 09:10 PM
djhatchtraxxx89
Oct 4, 2006 03:46 PM
Atheist
Aug 10, 2004 07:40 AM
amb4081
Feb 28, 2004 06:05 AM
