does 1994 honda accord automatic, have a filter?
Old Mar 26, 2004 | 05:15 PM
Overmind22's Avatar
Default does 1994 honda accord automatic, have a filter?
I went to drain my automatic transmission fluid today, and found that there wasn't a filter there.
is this normal? or do honda accords this year dont have a filter.
Old Mar 26, 2004 | 07:19 PM
brads94accord's Avatar
i believe they do have a filter but its a lifetime filter inside the tranny that doesn't need to be replaced. just drain it and fill it back up.
Old Mar 26, 2004 | 07:44 PM
mwkirchner's Avatar
Default Re: does 1994 honda accord automatic, have a filter? (Overmind22)
No Honda has the conventional type transmission filter that you find in other cars. Like was said above ... just drain and refill.
Old Mar 26, 2004 | 10:18 PM
Overmind22's Avatar
I changed the fluid and stuck in mobil 1 synthetic...The car has 96k and the transmission shifts funny...especially 1st to 2nd gear...it wants to jerk...
anyone have any ideas? maybe I should put one of those additives in there, or an ATF conditioner?
thanks
Old Mar 27, 2004 | 08:17 AM
miedosoracing's Avatar
Are you saying before or after you changed it, it shifts weird? You did put in transmission fluid, and not normal Mobil 1 synthetic that is in a gray bottle right??? That would make it shift really weird. What viscosity did you get? If so, I heard that ports that flow oil can get plugged.
Old Mar 27, 2004 | 08:32 AM
LeftCorner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Overmind22 &raquo;</TD></TR><TR><TD CLASS="quote">I changed the fluid and stuck in mobil 1 synthetic</TD></TR></TABLE>
Only use Honda ATF when changing the fluid. Adding a bottle of GM Synchromesh isn't a bad idea either.
Old Mar 27, 2004 | 08:54 AM
Overmind22's Avatar
Default Re: does 1994 honda accord automatic, have a filter? (LeftCorner)
the jerking started before i stuck in the mobil 1 synthetic ATF.
Anyways, you can use GM syncromesh in an automatic tranny car?
Old Mar 27, 2004 | 10:18 AM
FatJoe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Overmind22 &raquo;</TD></TR><TR><TD CLASS="quote">the jerking started before i stuck in the mobil 1 synthetic ATF.
Anyways, you can use GM syncromesh in an automatic tranny car?</TD></TR></TABLE>
if it can do wonders for a manual, it can do wonders for an automatic.
Old Mar 27, 2004 | 10:39 AM
Atheist's Avatar
I *think* they make some for AT cars
Old Mar 28, 2004 | 08:02 AM
showgunz's Avatar
Default Re: does 1994 honda accord automatic, have a filter? (Atheist)
Mobil makes Mobil 1 synthetic ATF but the bottle's a darker grey than their engine oils. I wouldn't recommend using that in a Honda, though. I don't know if the Mobil 1 ATF has all the lubricants and sealers in a Honda ATF.
If you want to get rid of your jerk, do a drain and refill about 3 to 4 times. It's a poor man's flush. It's safer than a machine flush since the machine may force a lot of debris through the internal screen (non-user-replaceable filter) and clog it. Instead, drain your ATF after driving about 100 miles and refill it. Drive another 100 miles, drain and refill it. Do this about 3 to 4 times and you should be able to pull most of your oil ATF out and have newer ATF in.
Old Mar 28, 2004 | 09:47 AM
FDAccord's Avatar
you CAN check the filters by unscrewing those two "cylinder" like things sticking out of the transmission. There's two, one on the top and one down below. Once you take it apart you'll see this rubber and mesh thing, sometimes you'll see particles on it.
mykiraa
Mar 13, 2020 04:10 AM
the soL that could
Jun 18, 2010 04:42 PM
bluefuse
Jun 29, 2006 09:52 AM
ArgGuy
Aug 6, 2004 05:37 PM
UncleRay
Feb 1, 2003 06:04 PM
