93 ls motor and trans into a 97?
Old Mar 26, 2004 | 02:56 PM
bushb20t's Avatar
Default 93 ls motor and trans into a 97?
Im trying to find a motor and trans for a 97 integra, will a 93 ls motor bolt right up? Or will I need custom mounts and stuff? I dont really care about power, I just want to throw a motor in this car. Also is the 97 transmission hydraulic or cable? are all automatic transmissions hydraulic? if not is the 97?
Old Mar 26, 2004 | 03:25 PM
SloGizzer's Avatar
Default Re: 93 ls motor and trans into a 97? (bushb20t)
it will drop right in there
Old Mar 26, 2004 | 08:51 PM
bushb20t's Avatar
so the transmissions are both the same(or same type?) atleast as long as they are auto right?
Old Mar 26, 2004 | 09:28 PM
maryzknight's Avatar
Default Re: (bushb20t)
if you have smog laws then an older engine wont pass. and why would you want a b18a in your car? its really weaker than a b18b and the tranny is worse also
Old Mar 26, 2004 | 10:20 PM
jdmtegx2o8's Avatar
Default Re: (maryzknight)
the transmission will fit, however it wouldn't work unless u get a consersion kit. the 94+ trannies are hydraulic. and the one in the gen2 is cable. so you need to convert it into hydraulic
NorCalIntegraLS
Mar 27, 2008 03:47 PM
civicb16eg
Northern California (Sales)
Feb 18, 2006 10:51 PM
rev210k
Jul 3, 2004 11:11 PM
