ZC swap into CRX HF...finally running
just a little info for anyone who wants to put a ZC into their HF...if you want to do this make sure that you change the engine harness to your hf harness... you will also nee to run a plug for the dizzy and Crank angle sensor or you can buy a subharness from Hasport for like $50 shipped...
when i did my swap it had an si engine harness and everything plugged up fine...it would crank but no spark....this drove me crazy and since most people with ZC swaps on here have Si's or Dx's it was hard to find any answers... i swapped the dizzy's coil and ignitor before i finally figured out that i needed to swap the engine harnedd back to my HF harness.....
i hope this will help alot of people out...
it's amazing...i posted many times on 3 different crx message boards for 3 days and never really got a good answer.....
this is just to help anyone out there with an HF....
Good luck swapping guys...
amh0001
Oct 4, 2004 02:44 PM
pyro_freak8
Mar 25, 2004 01:30 PM
