Stainless steel brake lines: Goodridge or Comptech?
Old Mar 26, 2004 | 10:38 AM
fso_BamBam's Avatar
New User
Default SS Lines: Goodridge or Comptech??
I'm about to order SS lines, which of the two would you recommend? Does it even matter? I seem to remember reading that the Comptech ones are a perfect fit, but the Goodridge lines have some minor fitment issues. Please advise.
Old Mar 26, 2004 | 10:42 AM
trutuner's Avatar
Default Re: SS Lines: Goodridge or Comptech?? (fso_BamBam)
I TOO WOULD LIKE TO KNOW!...-Roger
Old Mar 26, 2004 | 10:45 AM
Opie's Avatar
I used the goodridge ones on my 91 teg never had any issues with fitment if that helps. Edit* They did improve the feeling of my brake pedal but I didn't notice a dramatic change in break performance...
IMHO spend the money elsewhere. Unless you are in need of brake lines or heavily track your car I don't think they are worth it.
Old Mar 26, 2004 | 10:46 AM
Kengs's Avatar
Default Re: (opie)
APP
Old Mar 26, 2004 | 10:47 AM
MattD@Stoptech's Avatar
http://www.stoptech.com
bus stop's Avatar
another one to think about is StopTech.
The stoptech one have a layer of clear rubber to cover and protect the line
Old Mar 26, 2004 | 10:51 AM
Mugen Mike's Avatar
I had good luck with the Goodridge on my old EF hatch. I've got the Mugen SS lines on the Arrr now, which are also great quality.
I do agree with Opie, though. Not really a neccessary mod unless you're noticing a lot of brake fade with the stock lines (which happened on my hatchback a few times -- scary )
Philly_NBP_R's Avatar
Default Re: SS Lines: Goodridge or Comptech?? (whOsEvO)
<=== been running Goodridge SS lines for > a year now on the street - no problems at all. Definately stiffens up the pedal, and make it more linear IMO. Not a bad mod for ~100 bucks...
Old Mar 26, 2004 | 10:53 AM
thk's Avatar
thk
Members Only
Default Re: (kengs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kengs &raquo;</TD></TR><TR><TD CLASS="quote">APP </TD></TR></TABLE>
if you're an JDM *****. Waitaminute ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">http://www.stoptech.com</TD></TR></TABLE>
Saw these in person and they're definitely a better choice (IMHO) than Goodridge because of the protective coating over the SS braided sleeves.
Old Mar 26, 2004 | 10:58 AM
.RJ's Avatar
.RJ
SS lines are a wear item....
Old Mar 26, 2004 | 10:59 AM
Kengs's Avatar
Default Re: (thk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thk &raquo;</TD></TR><TR><TD CLASS="quote">
Saw these in person and they're definitely a better choice (IMHO) than Goodridge because of the protective coating over the SS braided sleeves.</TD></TR></TABLE>
APP = coated + no problem with fittings
Old Mar 26, 2004 | 11:00 AM
Saga's Avatar
Default Re: (kengs)
quit talking JDM
Old Mar 26, 2004 | 11:08 AM
Default Re: (kengs)
How much are the APP?
Old Mar 26, 2004 | 11:09 AM
nEoMuGen's Avatar
Default Re: (El Pollo Diablo)
Which ones uses Teflon/PTFE inner tubing?
Kengs's Avatar
Default Re: (nEoMuGen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nEoMuGen &raquo;</TD></TR><TR><TD CLASS="quote">Which ones uses Teflon/PTFE inner tubing?</TD></TR></TABLE>
Project Mu
Modified by kengs at 3:22 PM 3/26/2004
Old Mar 26, 2004 | 11:13 AM
BlueR's Avatar
Default Re: (kengs)
i gave up my set of APPs the "thk a/k/a *****"...
i went with the stoptechs...
but APP is noice!!! even the fittings are stainless
Old Mar 26, 2004 | 11:17 AM
nEoMuGen's Avatar
Default Re: (kengs)
Hey Kyle, didn't you said your Stoptech has inner Teflon tubing? Phew, almost got myself a set...
Old Mar 26, 2004 | 11:18 AM
.RJ's Avatar
.RJ
All SS lines should be teflon on the inside.....
Old Mar 26, 2004 | 11:20 AM
ZygSpeed's Avatar
So do the StopTech.
http://www.stoptech.com/products/ss_brakelines.htm
Just got a set in for the ITR.
Old Mar 26, 2004 | 11:28 AM
nEoMuGen's Avatar
Default Re: (zygspeed)
: Points finger at kengs: Shane mis-informed me!!
Old Mar 26, 2004 | 11:32 AM
thk's Avatar
thk
Members Only
Default Re: (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">i gave up my set of APPs the "thk a/k/a *****"...
but APP is noice!!! even the fittings are stainless </TD></TR></TABLE>
Old Mar 26, 2004 | 11:47 AM
Saga's Avatar
Default Re: (BlueR)
Good point
Most of the ones out there are with regular steel fittings, except Endless and APP...plus a few others not-as-well-known brands.
Old Mar 26, 2004 | 11:49 AM
Default Re: (Saga)
SS lines should be replaced fairly often (1-2yrs) anyway...so whats the point of having SS fittings?
Old Mar 26, 2004 | 11:55 AM
Saga's Avatar
You are right, that's why most do not come with stainless fittings.
but for the similarly priced lines (APP, Endless, Project Mu etc), it's definitely a plus.
Old Mar 26, 2004 | 12:02 PM
Default Re: (Saga)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Saga &raquo;</TD></TR><TR><TD CLASS="quote">You are right, that's why most do not come with stainless fittings.
but for the similarly priced lines (APP, Endless, Project Mu etc), it's definitely a plus.</TD></TR></TABLE>
priced....or overpriced...
