NEED HELP! I think my rear susp is F&%*
Old Mar 26, 2004 | 10:30 AM
vbphreak's Avatar
Default NEED HELP! I think my rear susp is F&%*
I recently put in ES bushings in the rear LCAs of an 88 CRX. I added the bolt/washer camber fix and changed the struts because the bushings in them where non existent. I got a pair of ITRs for cheap so just grinded down the steel sleeve and they fit.
Now the problem, a few months ago (the car was in storage for the winter), my brother hit a fairly deep pot hole, scraped a chunk of the tranny (now leaks), slightly bent a rim and now I think he screwed up the suspension as well. It looks like the ghetto diagram below.
FRONT of CAR
I I (R)
I / (just slightly though)
Does anyone have insight to what the problem may be and some recommendations of how to fix it. The problem is not as bad as illustrated but *quite* visible to the eye which may explain why it pulls to the right slightly.
Thanks!
Old Mar 26, 2004 | 10:41 AM
mr. carpenter's Avatar
Default Re: NEED HELP! I think my rear susp is F&%* (vbphreak)
bent lca or messed up lca mount?
m1am1sf1n3st
Jan 27, 2010 01:48 PM
OneCamJam
Jan 23, 2009 03:21 PM
Midori Green
May 4, 2008 03:02 PM
Digitalcivic
13
Apr 22, 2006 10:21 AM
agent007ppk
Feb 28, 2004 09:31 PM
