can i still boost my 97 lude....?
Old Mar 26, 2004 | 06:01 AM
GokuSs4's Avatar
Default can i still boost my 97 lude....?
Hello all...! i took my car to the shop a week ago to get some minor work done...! oil change, tire rotation and stuff...i had them do the compression test and leakdown, the mechanic said that everything checked out ok....! the only thing that worries me is that when they placed the car on the lift for the oil change, i saw some major leakage right by the intake manifold...i really dont know much about cars and i really need your help...! the mechanic said that the valve cover gasket needs to be replaced and thats where the leaks coming from but as far as the engine he said that everything is still fine....! im really planning to build up my motor new pistons resleeved and some head work, then put on a jrsc....! would you guys still boost a 100k mile car......? pls help..! thanks in advance for reading and replying to my post..>! thanks again...!
Old Mar 26, 2004 | 07:31 AM
pentaq's Avatar
Default Re: can i still boost my 97 lude....? (GokuSs4)
A valve cover gasket is very cheap and you can replace it yourself. Using a high temp silicone or hondabond on a gasket also helps preventing further leaks.
Old Mar 26, 2004 | 08:56 AM
homesauce's Avatar
Default Re: can i still boost my 97 lude....? (pentaq)
if u planning on building ur block and tuning, of course u can boost ur car even with 100k
Old Mar 26, 2004 | 09:01 AM
Sam1am26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GokuSs4 &raquo;</TD></TR><TR><TD CLASS="quote">im really planning to build up my motor new pistons resleeved and some head work, then put on a jrsc....! would you guys still boost a 100k mile car......?</TD></TR></TABLE>
If your doing all that I'm assuming you will replace the bearings anyways, or atleast it wouldnt make since not to at that point, so you would have a brand new engine basically anyways... build it and then boost the hell out of it...
Old Mar 26, 2004 | 11:24 AM
GokuSs4's Avatar
Default Re: can i still boost my 97 lude....? (Sam1am26)
yah im going to build up the motor completely, i read it hear all the time bottom end build up and some headwork, im not sure if im even saying it right. like i said earlier i really dunno anything about cars...hehe sorry if i bug..i want to learn...! but im still debating whether i go turbo or supercharger..going to be a daily driven car probably 15-20 miles a day, house school work...! which will be more reliable for me the jrsc or turbo? which will require less maintenance...? thanks again....!
central_driver
May 18, 2010 06:37 AM
90CivicDaily
12
May 4, 2008 10:12 AM
DJNauTicz
Apr 11, 2007 10:43 PM
alpha
Oct 27, 2005 02:20 PM
slowls
Jun 25, 2003 10:24 PM
