Vtec problem on '91 b20 CRX
Old Mar 26, 2004 | 01:28 AM
Speedball's Avatar
Default Vtec problem on '91 b20 CRX
Swaped b20vtec in my '91 obd0 crx. Was driving about a week with everything working fine. Yesterday vtec stoped working. Don't know what was the cause. I washed the car before that happens and ran into one big gap on road. I can't remember any more happening before.
code 23 is on. i am running without knock sensor. Could that be because of bad fuel or spark plugs? any ideas?
Old Mar 26, 2004 | 03:01 AM
japspecjohn's Avatar
Default Re: Vtec problem on '91 b20 CRX (Speedball)
Im not sure what code 23 is but check your ground wire for your vtec solinoid....
Old Mar 26, 2004 | 05:51 AM
ThefirstPACT's Avatar
Default Re: Vtec problem on '91 b20 CRX (japspecjohn)
check all wiring! Make sure ecu pinouts are still "in"!
edit: oh yeah cel 23 (knock sensor) it should have no effect on vtec unless your obd1.
Old Mar 26, 2004 | 07:00 AM
13oclock's Avatar
Is there anyway you could post a howto for your engine swap...I am about to begin my engine swap and am also using a B20
Old Mar 26, 2004 | 09:44 AM
Speedball's Avatar
Default Re: Vtec problem on '91 b20 CRX (13oclock)
Problem solved. Battery ground wire was loose.
Old Mar 26, 2004 | 09:47 AM
Speedball's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 13oclock &raquo;</TD></TR><TR><TD CLASS="quote">Is there anyway you could post a howto for your engine swap...I am about to begin my engine swap and am also using a B20</TD></TR></TABLE>
Well, it was b16a &gt; b20b swap. First swap on this car was d16 &gt; b16. U can find the answers here (HT) on all questions u'll have on this swap. I did the same.
Laojoeturbo
34
Jun 24, 2009 08:47 AM
91EF_Si
Sep 25, 2007 08:40 PM
ls_vtec_crx
20
Jan 18, 2005 10:38 PM
nismo
Apr 2, 2004 05:31 AM
