ITR cat
Old Oct 23, 2001 | 05:40 AM
ITR #1202's Avatar
Default ITR cat
is the Itr cat already high flow or would a aftermarket one better with
new exhaust?
Old Oct 23, 2001 | 05:43 AM
sackdz's Avatar
Default Re: ITR cat (ITR #1202)
aftermarket
Old Oct 23, 2001 | 05:55 AM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: ITR cat (sackdz)
You changing exhaust diameter? 2.5" collector header perhaps? I'd just keep the stock one unless you need the larger one.
Old Oct 23, 2001 | 06:04 AM
BITeR's Avatar
New User
Why not replace cat with a tube? Cheap and effectve. Anyone done this?
My friend did so on a 240sx turbo (euro), suddenly he could hang (well sort of) with me.
Expected hp gains?
Old Oct 23, 2001 | 06:20 AM
Dropspeed's Avatar
Default Re: ITR cat (BITeR)
The cat for the ls/rs/gs and ITR is the same. On my ITR with a Mugen header and Mugen exhaust, the Carsound cat was good for 5hp and 5 pd ft @ peak, The best part was 15pd ft and 12hp @ 4500 rpm I didn't go with a straight pipe because I'm a stuborn bastard and do things my way.
Mattj
Old Oct 23, 2001 | 06:24 AM
BITeR's Avatar
New User
Default Re: ITR cat (Dropspeed)
So a straight tube should at least get the gains you got from the carsound cat?
what is the price for that cat.? Sounds like a nice mod.
Old Oct 23, 2001 | 06:30 AM
DutchITR1689's Avatar
I wouldn't bother swapping the stock cat with a Carsound cat if you still have your stock header. An 60 mm straight pipe helps a bit with your stock header. You have to remove a bottleneck also.
Old Oct 23, 2001 | 06:37 AM
Ryuji's Avatar
New User
Hi,
I did replace my cat by a tube and all is fine.
I didn't notice particular change because I did it
a month after I bought the car
(not used to the car )
Old Oct 23, 2001 | 06:51 AM
BITeR's Avatar
New User
Default Re: ITR cat (EuroITR1689)
Ok, I need a header then, what is best for the euro R? (Besides Mugen)
Aslo any other problems if I decide to replace cat with straight tube?
Old Oct 23, 2001 | 06:56 AM
You won't pass the annual emission test. If you put a straight pipe now, you will have to modify it if you buy a JDM header. The DC JDM 4-1 is a good one for the price.
If you get the header, your stock cat won't fit anymore (for the annual emission test)!!!
Old Oct 23, 2001 | 07:01 AM
BITeR's Avatar
New User
Ok, let's say I want to keep the cat. or get the carsound cat and a header, is DC the way to go on euro R's then.
Maybe header first, then cat?
Or header, straight tube, then stock cat when emission tests come around. (Only every 2. year in Norway!)
What fits with what?
Old Oct 23, 2001 | 07:31 AM
USDM ITR engine is not very different than the Euro B18C6. We have a higher compression and other small things (closer to JDM).
So, if a header is good for the USDM B18C5 then it's also good for us..
DC JDM 4-1, Carsound cat = 2.5 inch flange.
Stock header, stock cat = 2.25 inch flange.
You can make a 2.25" or 2.5" or 60 mm straight tube or any size you want.....
Old Oct 23, 2001 | 08:36 AM
Splat's Avatar
Mattj
USDM Mugen or JDM Mugen? What diameter collector and cat?
Test pipe = illegal in most, if not all, (US) states.
Old Oct 23, 2001 | 10:33 AM
VT-ITR1's Avatar
New User
Default Re: ITR cat (itr009)
ive got JDM header to 2.5" test pipe, reduced to stock cat back... i love it, only draw backs are
a)illegal
b)brown residue buildup on back lower bumper
Old Oct 24, 2001 | 01:07 AM
BITeR's Avatar
New User
Default Re: ITR cat (00 ITR 506)
I used to study in Blacksburg!! Loved to street race there. Got pulled over once in my charged crx for squealing tires coming out from a light!! hahaha
sohctodohc
May 15, 2007 08:43 AM
_VTEKNU_
Apr 30, 2007 02:47 AM
Project X
Apr 8, 2003 01:04 PM
Rdriven
Nov 28, 2002 09:20 PM
SIK IN DA HED
Sep 6, 2002 01:10 AM
