98 accors srs module reset if bags blown and replaced
Old Mar 25, 2004 | 07:48 PM
95swappedsi's Avatar
Default 98 accors srs module reset if bags blown and replaced
as title says i have a friend who fixed a wrecked 98 accord and replaced the bags and i was wondering if u can use the MES plug procedure to reset the module if they have been set off or if it only works for the light if there is a problem....thanx
Old Mar 25, 2004 | 07:53 PM
iam7head's Avatar
Default Re: 98 accors srs module reset if bags blown and replaced (95swappedsi)
most of the time the srs light could be trigger by the slightest problem.
try to reset it, if it would go away, there's something wrong.
just jump the mes connector
Old Mar 25, 2004 | 07:54 PM
Default Re: 98 accors srs module reset if bags blown and replaced (iam7head)
werd thanx ill try it next time i go home for him...but i just didnt know if it would work if they had been blown didnt know if someone had done it b4 but i will deff try it....thanx
Old Mar 25, 2004 | 08:32 PM
solo2slocivic's Avatar
if the bags were blown the control unit MUST also be REPLACED or the system will not work.....
Old Mar 25, 2004 | 09:03 PM
one clean ride's Avatar
yea you need to either replace the srs unit or get it repaired professionally. According to my 94 helms manual, after all items are replaced meaning the srs unit, airbags, srs cable reel (if necessary), sensors (if applicable) are replaced, then the srs system will self check itself when the key is in the II ignition position and go on then off after 6 seconds if the system is fine. If the SRS light remains on, then you should proceed to trouble shooting. On my 94, it doesnt have the MES connector option to reset so I dont know if that is the same for your 98.
Old Mar 26, 2004 | 03:28 AM
oh well damn....thanx...i know u can get the module reset just wasnt sure how...u can go to honda or ship it off....thanx for the info
Genesis0863
10
Jan 30, 2013 08:20 AM
helpmycivic
12
Jul 1, 2007 09:54 PM
CHiNkStEr
Mar 7, 2006 10:11 PM
WickedKP
Sep 4, 2003 10:04 PM
net1vet
Apr 3, 2002 10:44 AM
