Grinding gears shifting into 3rd.
Old Mar 25, 2004 | 07:02 PM
tony92875's Avatar
Default Grinding gears shifting into 3rd.
Hey guys,
I have a 95 Prelude S that I just bought and seems to be in perfect shape in almost every way except for 3rd gear. No matter how perfect I shift into 3rd it's always rough and there is always grinding until it's completely in gear. This isn't my area so I'm not sure where to start looking. The rest of the gears seem to be fine. It's a smooth shift into 1st, 2nd, 4th and 5th.
Anyone have any ideas?
Regards,
-Tony
Old Mar 25, 2004 | 07:18 PM
SelfImage's Avatar
Default Re: Grinding gears shifting into 3rd. (tony92875)
It is most likely your Sincerniser is out..
Old Mar 25, 2004 | 07:19 PM
PrecisionH23a's Avatar
It's the 3rd gear synchro going bad. It happens to a lot of prelude transmissions. Do a search about synchro, you'll find a lot of info on it. You can try running GM synchromesh tranny fluid as a bandaid to fix the problem temporarily.... sooner or later you'll need a rebuild.
Old Mar 25, 2004 | 08:37 PM
accord387's Avatar
Just get penzoil synchromesh from autozone... same **** but a lot cheaper, and after that try and come up with the extra cash to get a new synchro and installation b/c penzoil can only do so much for only a limited amount of time
Old Mar 25, 2004 | 08:52 PM
Cottonwoodz's Avatar
From 2nd, just dip it into 4th and then up to 3rd... No grind
Old Mar 25, 2004 | 09:15 PM
Luchini's Avatar
Samething happens to me while shifting to 3rd. Anyone get their tranny rebuilt? If so what was the total cost?
Old Mar 25, 2004 | 09:29 PM
Default Re: Grinding gears shifting into 3rd. (Luchini)
If you replace everything, you are looking at spending around 800 just on parts and around $200-250 on labor. Thats IF you remove the tranny and install it back yourself.
Old Mar 25, 2004 | 10:06 PM
Luchini's Avatar
Default Re: Grinding gears shifting into 3rd. (PrecisionH23a)
Any idea what a tranny shop would quote for labor and parts?
Old Mar 26, 2004 | 11:44 AM
Notorious869's Avatar
i got a '00 lude, and all it took was missing 3rd one time and i needed a rebuild, as far as i know third is a problem for all prelude owner, anyways, it costed like 900 for a good rebuild & a lifetime warranty
Old Mar 26, 2004 | 12:49 PM
tony92875's Avatar
Default Re: (Cottonwoodz)
Actually I've been doing that since yesterday. I noticed that it worked well. But I also noticed that if I go from 2nd to nutral and let the car rev down to under 3k and THEN shift into third it doesn't grind. I've only done that a few times so far so I'm still testing out that situation.
Old Mar 26, 2004 | 12:53 PM
tylek17's Avatar
Default Re: (tony92875)
well you could also double clutch it then it shouldn't grind.
Old Mar 26, 2004 | 02:48 PM
SKDRCR's Avatar
Default Re: (tylek17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tylek17 &raquo;</TD></TR><TR><TD CLASS="quote">well you could also double clutch it then it shouldn't grind.</TD></TR></TABLE>
Old Mar 26, 2004 | 03:46 PM
tony92875's Avatar
I'm working my double clutching now too It's going to take me a while though so I'm going with a combo of penzoil synchromesh and going from 2nd -&gt; 4th -&gt; 3rd ... for now
Old Mar 30, 2004 | 11:09 PM
luda94's Avatar
the syncro costs about $3, the big cost is labor.
Old Mar 31, 2004 | 01:04 AM
Luchini's Avatar
Default Re: Grinding gears shifting into 3rd. (Notorious869)
900 bucks!? Man maybe I shoulda got that extended warranty for only 12 dollars more a month for 36 months....
Old Apr 2, 2004 | 02:39 PM
tony92875's Avatar
UPDATE
had the old transmission fluid flushed out and had it filled with synchromesh ... no change.. all of my other gears shift as smooth as silk though Looks like dipping 4th gear or double clutching until I get the synchro replace or tranny rebuilt or something else.. I'm getting better at double clutching though .. so that's a plus
Old Apr 2, 2004 | 04:01 PM
Monkey Fing a Coconut's Avatar
it takes a good 400 miles/week or two for the syncromesh to kick in....
nicokpe
Apr 25, 2008 08:55 PM
torr
May 22, 2005 03:49 PM
korndog
Mar 11, 2005 09:20 AM
ebelp
Jun 24, 2004 07:08 AM
b00stn
Oct 25, 2002 02:22 PM
