g35 wheels on rsx
Old Mar 25, 2004 | 06:54 PM
ViZ's Avatar
ViZ
Default g35 wheels on rsx
will it work??
the G35 offset is +30
Old Mar 26, 2004 | 03:29 AM
jspek.com member's Avatar
i ran weds @ a +35...it worked..but man its pushing it...see if you have enough matl on the pad of the wheel to shave off and change the offset.
Old Mar 26, 2004 | 07:56 AM
NeVeR bLoWn's Avatar
Default Re: g35 wheels on rsx (ViZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ViZ &raquo;</TD></TR><TR><TD CLASS="quote">will it work??
got a pic?
Old Mar 28, 2004 | 09:40 AM
theSYNDICATE's Avatar
From: Derek Jeter drinks wine coolers,, The Nation, USA
Just run some spacers.
Old Mar 28, 2004 | 09:04 PM
nickzed20's Avatar
Default Re: g35 wheels on rsx (91 Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91 Teg &raquo;</TD></TR><TR><TD CLASS="quote">Just run some spacers.</TD></TR></TABLE>
i believe its the other way around. positive offset is towards the outside of the wheel. So since it usualy runs a higher offset then +30, it will need the bolts to be furtur outwards, so that the wheel will be pulled closer to the car. (instead of pushed away, which is what a spacer would do)
btw: did that make any sense? im confused!
Old Mar 29, 2004 | 05:31 AM
chunky's Avatar
g35 wheels are HUGE.
you'd definitely need non-stock g35 tire sizes. plus the offset is different front & rear isn't it? you could maybe run two sets of the front wheels. . ..
Old Mar 29, 2004 | 06:28 AM
TheNewPunk's Avatar
Default Re: (chunky)
I want to see how this looks. How heavy are the G35 wheels?
TsukubaSpec
19
Nov 6, 2007 11:56 PM
90hbvtec
Mar 2, 2007 08:11 PM
E-Money
Nov 17, 2006 07:22 AM
130R
14
May 31, 2005 10:38 AM
